I am working on my first N scale layout and my hands are less than steady , resulting in a few 1/8 to 1/4 Inch gaps between rails in several places. The problem is the roadback and track are already laid down. What sort of product could I use to full these gaps without too much reduction in the current passing through the rails?
Im not sure how long the rail joiners are in n, However in ho I use a short piece of scrap rail, slid into the joiner filling the gap as tje joiner (knock on wood so far) will hold it in alignment and still passes the curent.
I have used short rail pieces and soldered them in place. For smaller gaps it may be easier to fill with epoxy. I have done this using the two part putty like epoxy. Mold it in the gap and then after it cures clean up with sand paper - a moto tool really helps here.
Enjoy
Paul
Sometimes rail slides back and forth easily where it’s joined to the ties, especially flex track, by using finger pressure or when tapped gently with a tack hammer. If you could do this, you could reduce the number of gaps that you would have to fill. Be careful on curves so that you don’t break the little plastic “spikes.” The resulting gap could be filled with scrap rail which would slide right under the “spikes” as long as the ends of the replacement are filed smooth. You would have to lift the track in one place to be able slide the rail in place. Also, make sure the gap is in a straight section of track.
