I recently removed the lettering from a Lifelike 0-8-0 using MicroSol and a pencil eraser which caused a noticable difference in the paint sheen. I posted a question about that on this forum and the people who responded said I should just go ahead and spray a gloss coat both to reduce the sheen difference and prepare for decals.
So, that’s what I did, eventually. I spent a great deal of time beforehand masking off surfaces I didn’t want sprayed. Very time-consuming.
My question for this forum is: What would you do? In my case, the engine was black and I wasn’t repainting it, just removing the factory lettering and applying decals for my home road. Since all I wanted to do was spray a gloss-coat, was it really necessary to mask off all of the other surfaces? Would you have bothered? Would you have sprayed the whole engine even though only a fraction really needed it?
I have 40 more black steam engines to do - remove lettering, gloss-coat, decal, flat-coat. Not masking off 9/10ths of each engine would be a big time-saver.
What would you do?
Thanks for your thoughts,
Jeff
