What Year for Yellow Box Atlas locomotives?
Good Evening to all,
I recently purchased one of the “Yellow box” Atlas locomotives (GP40) road #3084 off of ebay. Was curious if any of you Atlas gurus out there might know between what years were these “yellow box” editions produced? I believe that some were made in Austria and some in China? I have not received the engine yet so I cannot check any marking on it as I do not have it in my hands yet. Thanks in advance.
Regards,
Brad
I’m going to guess mid to late 1980s… SOME yellow box models, had Kato drives as well. The GP7,9, RS11, RS1, RS3, F3,7,9 (did I miss any?)… I’d suspect your GP40 is an Austrian made version, similar drive to Athearn (Blue Box) though much quieter as I remember it…
edit: Sorry for the error, the F units with Kato drives are Stewarts (late 1980s early 1990s)…
1975 was the first year. Check out the Atlas trains collectors resource
Brad,
The link dingoix provided is about the best site for info right now. It only lists the 1975 road names; the second Atlas and the Con-Cor runs were not included.
Here is some info concerning the mechanisms. Over the years there were 4 different versions of the GP-38/40s. They are, in chronological order:
  • Atlas/Roco - 2 flywheels w/o circuit board, 10T gearing.
  • Atlas/Roco - 1 flywheel w/circuit board, 10T gearing.
  • Con-Cor/Roco - 1 flywheel w/circuit board, 10T gearing, updated Roco motor.
  • Con-Cor/Roco - 2 flywheels w/new circuit board, motor, frame and 14T gearing.
Note:
Versions 1-3 are interchangeable concerning parts.
Version 4 shares only the body and truck side frames with version 1-3; the drive train is the same as the second run of the Atlas/Roco FP-7.
Versions 3-4 has “Made in Austria” ground off the bottom of the trucks; some have a sticker on bottom of frame “Assembled in Mexico”.
Hope this helps,
Jim
Jim, thank you so much. Now I know why my FP7 has only 1 flywheel. How do I tell if it’s Atlas / roco (version 2) or Con-Cor / roco (version 3)?
You can also find information about older Atlas train engines at the following link. There are diagrams and reference information available.
http://www.hoseeker.net/lit.html
Larry
dingoix, you are welcome.
Con-Cor never sold the FP-7. Atlas ran these twice with the versions as follows:
  • Atlas/Roco - 1 flywheel w/o circuit board, 10T gearing
  • Atlas/Roco - 2 flywheels w/ circuit board, new motor, heavier frame and 14T gearing.
Note:
Only the body and truck side frames are interchangeable between the 2 FP-7 versions.
The second version of the FP-7 uses the same drive as the last version of the Con-Cor/Roco GP-38/40s
I have not seen the ER Models version of the FP-7, it may be the same as the second Atlas version. Perhaps someone who owns one can comment.
Larry, you have a good site there.
Jim
Thanks. It sounds like I’ve got an old one.
