water or solvent based paints? I will be using both brush & air brush.
thanks
Pat
thanks
Pat
Both will work equally well. However, some older solvent-based stuff (such as Floquil) will damage plastic. With that, spray on a coat of primer first.
I usually use solvent based for the base coat and the use water based for the details. I find that the solvent will not attack the plastic if I airbrush fine coats.
Either works well. I prefer water based: easy clean up and low odor.
Nick
I’ve used both without problems… I mostly use water base nowadays for convenience sake.
With the solvent based paints the thing you want is an enamel. That won’t attack the plastic. A laquer based paint will attack it.
I like the solvent based paints myself, but thats probably because I’ve been using them for 30+ years now, so I’m comfortable with them.
Water-based acrylics, the craft type, avail at W-Mart. Cheap, effective, you can even weather locos and structures with it in a wash.
