After I get done with my current major renovation of the Rock Ridge and Train City. I’m going to tear out this bridge…
…and replace it with a scratch-built trestle bridge. In doing so I am also going to remove the current base of the layout and drop it 6" so it is a taller bridge. Unfortunately, that means relocating the control panel. [dread!]
This scene is one of the most impressive I have ever seen - and I have seen a LOT! Not only is the model work outstanding, but the roads, signs and scenery are breath-taking and soooo realistic. I love how everything blends so well together. Has your work ever appeared in the hobby press?
At first I thought I was looking at Harold Werthwein"s Erie layout. His Starrucca Viaduct is a museum-quality model and so is yours. They could be twins!!!
Man, what an honor it is to have you share your work with us. How about showing us some more?!? I would love to see some of your building structures!
Cliff - Thanks for the compliments !!! Nope, no model railroad press … yet ! Funny you should mention Harold’s bridge and mine looking like twins - Harry McGowan built the Starrucca Viaduct on Harolds layout. Harry was kind enough to send me one of his casting masters he used to build Harold’s bridge. I made a mold from this and casted my own copies to build my version … so Harold’s bridge and mine SHOULD look like twins !!! LOL
Timothy: Once you get the Beichstahl out of the box, you’ll be both amazed and pleased at how easily and well the bridge goes together, and how easy it is to ‘kitbash’ if you’re so inclined. I can guarantee you’ll like it, and it’s an attention-grabber no matter where you locate it on your layout.
When you get it built and installed, post some pics, okay? It’s really QUITE a bridge!!
Tom [:D]
Tom :
I agree – it is one he!! of a bridge ! But I have not built any models since I was a kid, so my skill are a bit rusty, to say the least. The instructions do seem to be very clear and logical (leave it to the Germans!).
As to when I’ll have it built … considering I’m still only in the early stages of building the benchwork, I won’t dare venture a guess as to when I’ll be able to show people what it looks like.
Those are all some pretty impressive bridges. I have a (scale) 350’ tressle on my garden railroad and one that is almost exactly like it paralell to it, the only difference is that it is an inch shy of the same length.
I am always in awe when I see these photo’s. I would love to have the corner available for a bridge like that. I have 14" depth where my bridges go. This is what I ended up with (still under construction.
Wow!! Tons of impressive bridges here, and well worth the wait to view. My first three pictures are of bridges in areas awaiting scenery. The first photo, of two bridges over the Speed River, was an attempt to turn an operational problem into a scenic advantage. The lower line is dropping on a rather stiff 2.5% grade, while the upper line climbs at a similar rate. Where both lines reach the ends of their respective grades, the layout will be double-decked. The lower grade is only about 15’ long, while the upper is around 45’. I hope to be able to use a lot of trees to make the bridges fit into the scene a bit more inconspicuously. The bridges are a combination of Micro Engineering and Atlas parts.
My intention is to fill the valley under the bridge with tall trees, making the bridge blend into the scenery, as if it’s been here for a while.
This bridge, over Chippawa Creek, consists of two Atlas deck trusses, plus a Micro Engineering deck girder, hidden in the trees to the left.
This last bridge, over the Maitland River, near Lowbanks, is made up of Atlas, and M.E. deck girders, with a Central Valley truss over the deepest part of the channel.
Alan, that is a great scene. What I added was cliff to the ceiling, and then put N and Z scale trees and scenery at the top for forced perspective. It makes it look even larger. You could do that and improve an already great scene.
