I think I will buy one in the future. It needs to clean all kinds of track i.e. o27, gargraves , o27 switches, gargraves switckes. Which one would you recommend…Thanks…Tim
http://www.centerline-products.com/rail_wheel.htm
After you buy it I’ll tell you the correct way to make it work.
On second thought, I’ll tell you now.
Use Goo-Gone on the roller on the centerline cleaner and run it around the track. On grades the track can get slippery, so be warned. After you run the cleaner a few times change out the roller to a dry roller and use tissues to stop the roller from turning. Run the cleaner around the track to dry off the GOO-GONE.
It works but if you leave the GOO-GONE on, the trains will not go up any grades.
If all else fails, you can always use a rubber eraser. [:-^]
I use the centerline, but recently added a NE Trains car behind it and it works much better in this combination.
The NE trains car is the one with the figures and details that come on top of a flat car. I run the Centerline with Goo Gone and the NE trains car dry to dry up the goo gone.
