What's the worst locomotive you have ever owned?
My worst locomotive that I have ever owned is a Proto Heritage 2-8-4.
This was the first edition model and while it looked great it has no pulling power.
Two box cars on a 2 % grade was all it could handle. I remember reading a review in Model Railroader of this engine and in passing it did mention slippery drivers, however, the reviewer thought with a good run in that would solve the problem. Wrong.
It could not be upgraded with the optional traction tires that Walthers added to the later editions.
I was lucky and traded it off for a Heritage 2-10-2 that came with the optional traction tires but strangely did not need them.
A Life-Like ‘Teakettle’. Those train set quality locos from the 70’s were almost universally junk.
This.
A Lindberg switcher from the early 60s.
Worst locomotive huh? Well, a Spectrum K4 blew a decoder and never worked right even after trying to hard-wire a couple times but I still liked the loco quite a bit. One day I’ll send in for a replacement.
Alvie
I had said I couldn’t pinpoint my best in the other thread; I can DEFINITELY pinpoint some of my worst, as follows (all HO scale)–
  • Bachmann E60CP
  • Atlas Alco S2 (yes, you read that correctly)
  • Atlas/Roco GP40
  • Atlas/Roco/Con-Cor GP38AC
  • Walthers Trainline (pre-P1K) GP15-1
The Trainline GP15-1’s wiring completely failed after about 1.5 years of use and would not work at all; I elected to completely gut it, give it a set of Athearn trucks, and now it’s a fairly nice dummy unit on my layout (hoping the P1K model doesn’t do that!!)… I’m baffled by the bad luck I’ve had with all of my Atlas products; it could be because all the Atlas products I own are all fairly old models (the GP38AC and GP40 both had their motors burn out, while the S2 just quit working one day, and to this day I don’t know why), but regardless of their age, they’ve earned a spot on my worst model list! As for the Bachmann electric, simply put, I’m thinking of a four letter word; begins with “s”, ends in “t”, and it isn’t “soot”…
And someone else may have had excellent experiences with these models; I’m basing my opinion here on the examples on my layout…
When I think of ‘worst’ locomotives I usually think of their design, not whether a loco was a defective unit off the production line. Any loco with a defective drive train can be repaired if the parts are available.
But as far as design goes, I’d say anything with a pancake motor is garbage. That includes the Bachmann train set locos, some of the old Model Power stuff, and Life-Like train set locos. I had a few pancake-motored locos when I was younger, and they eventually disappeared after I discovered flat can motors with dual flywheels.
In my earlier years, with no money for brass, I lusted for a set of ATSF E units. Finally I got a pair from Model Power - I believe sometime in the late '70s. The things never, ever ran for more than a few feet. No, it wasn’t due to track or wiring problems, the locos were just junk. I eventually gave them away - which in itself should tell you of their worth.
My second set of “worst” locos was the Model Power ATSF F7 units. They ran, but kept growling and losing contact from trucks to motor. I paid $5 each for them brand new - which should give you an indication as to worth.
Hmmmm…I’m going to have to say a Broadway limited diesel dcc and sound believe it or not. Cannot get that sucker to not derail on a certain curve on my layout. The only one out of about 20 other locomotives. Sent it in for repair, got it back the same as it went in.
Jarrell
I’ve got a Athearn Genesis SD75I that I have added to the collection cabinet, never to be run again. Nice looking but a turd once it hits the tracks. I’ve got 6 others that are great.
I think I can go you one better. I have the original RC version. A good looker, but no weight, and plastic drivers. Could barely pull the tender and two cars that came with it. MY little Lionel 0-6-0 ran rings around it. Today it’s the only piece of G-scale I have left, as a static model that sets on top of my computer desk.
Probably a HO Lionel GP30… can they call it a motor?
Matt
Hum, so may to pick from!
I am going to say it is a tie between a Athearn RTR SD 50 and a PK2000 E-6.
The E-6 will not track period even on K-10 Model Trains 32 inch turns. Have not ran it for 4 years.
SD 50 on the other hand has BBQ 4 decoders. Takes month’s, but it will let the smoke out.
Cuda Ken
Similar situation to David B. My Tyco UxxC from the mid 70"s. It was my first loco, never ran well and has been on the dead line for the last 20+ years. But I’ll never part with it.
Considering price, reputation, era of construction, etc - by far my worst TWO locos were the two Broadway Limited Heavy Mikados that I had to tear completely down and rebuild as if I was bulding a kit. And I had to make parts from incorrect parts because Braodway could not supply the right parts - these locos have been made by many different vendors for Broadway, and while the basic design is the same, there are about 3-4 different “versions” with slight differences.
As a side note, it is interesting to read others experiances and compare with your own.
I bought two Genesis Mikados, neither one has ever cracked a drive gear.
I have two Mantua/Tyco Generals, both run flawlessly and pull well.
I had a Lindberg switcher, it was too fast but otherwise ran fine.
And, of course this thread started with a “bad” piece of Bachmann, I have over 40 Bachmann locos and have had only three problem ones - all made good by Bachmann - can’t say that about Broadway.
A lot of locos people have mentioned are just train set junk, and that was known fact the day they were made - let alone now, 10, 20 ,30 years or more later - regardless of brand.
I don’t own any Athearn SD70 whatevers because I do not model that era, or collect anything outside my modeling interest, but every piece of Athearn I have owned owned was just fine - especially considering the price and era of some of it.
On the low end, you get what you pay for. On the high end you sometimes get an unpleasant surprise.
In the middle you often get sold value, even if it requires a little modeling skill to make it “perfect”.
Sheldon
My worst? Ok.let’s see then.
HO.
Hands down it was the Lindberg SW1 I bought in the early 60…This locomotive had a spring drive belt and would slink its way down the track----if the spring didn’t break first.
N Scale.
Back in 82 I bought a Model Power Alco C420 that shake going down the track…I named it “old shaky” and it became a “stored” locomotive next to the engine house.
Three come to mind as the absolute worst that have resulted in my just breaking them down for parts.
Older (80’s) Bachmann 2-8-0’s (blech). Older Bachmann PRR K-4’s. Followed by an AHM S-2. I don’t hold the older models against Bachmann though.
For worst performance in relation to cost for an out-of-the-box loco, my BLI NYC Hudson from the first run. Not so good running. Bad quartering, etc. Lot of work to get it to run smooth.
My worst ones 4 MTH SD70ACe that were purchased last January.
2 Factory equiped with sound , that don’t stay programmed. Sent to MTH for repairs, going on 3 months now, still waiting.
2 DCC ready that smoke decoders within minutes. Still waiting for replacement motors since last February. MTH is ignoring my emails.
Surely you are kidding right? Nothing built by MTH could ever be defective - just ask Mike Wolf.
Sheldon
No kidding Sheldon to be exact however I must say that 5 of these SD70 from MTH where purchased between me and a friend. One of them a SD70 M-2 is running very well. The others 4 no.
Worst locomotive that I ever owned was a Bachman 2-6-0. It would not run worth a hill of beans. I had some “electrical wizards” try their hand, but never got it to run reliably.[tdn]
