Preface
About two years ago, the NMRA put forth a proposal for large scale wheel and track standards. A copy of that proposal made its way into my inbox for me to look over. I read over what they had proposed, and found it quite out of line with what the large scale community had been doing. I drafted a letter to the NMRA expressing my concerns, going further to question the NMRA’s involvement in large scale, given the perceived mutual exclusivity of the two communities. I was expecting a “thanks for your note” response at the most; more to the point, I was fully expecting to be completely ignored. Instead, the NMRA asked me to work with them, even to take a leadership role in the process. I could hardly justify turning them down, so I agreed to take on what had up to this point proven to be a very quixotic task.
The Process
Over the next year or so, I gathered information on what standards currently existed (G1MRA, MOROP), as well as measured wheels and track to see who was doing what, and how they compared to those standards. I talked to manufacturers and and others who have been involved in this process in years past to get their perspective. The goal was to come up with a set of standards tight enough to where trains would stay on the rails, but loose enough so that they allow for smooth operation of most of the models already being produced. Together with Gary Raymond, the NMRA’s technical coordinator for large scale, and input from others in the large scale community along the way, we drew up three “levels” of standards for large scale, tailored to match the NMRA’s standards format. Once we had our numbers put together, we took them to Didrik Voss and Ed McCamey, who head the NMRA’s standards committee. (Forgive me if I’m getting the exact titles wrong.) Didrik and Ed took the numbers we came up with, and ran them through a series of mathematical equations that check for incompatibilities (i.e., wheels wider than track, etc.), a
Together with Gary Raymond, the NMRA’s technical coordinator for large scale, and input from others in the large scale community along the way, we drew up three “levels” of standards for large scale, tailored to match the NMRA’s standards format. Once we had our numbers put together, we took them to Didrik Voss and Ed McCamey, who head the NMRA’s standards committee. (Forgive me if I’m getting the exact titles wrong.) Didrik and Ed took the numbers we came up with, and ran them through a series of mathematical equations that check for incompatibilities (i.e., wheels wider than track, etc.), and came back to us with their results.
UNQUOTE:
Forgive my curiosity…
WHAT Equations did they use and WHERE did they source them from ?
Just a simple question from an EU citizen and non NMRA member…
Since I have invited the NMRA via their representative to explain and document the validity and source of their formulae use for the generation of their tabled data. I think it meaningful and worthwhile to the discussion to examine the data tables and formulae that I have used to: design and built my own locomotives, and trackwork…
The source volume is (of course), “Model Railways, Their Design, Details, and Practical Construction” by Henry Greenly Associate of the Institute of Locomotive Engineers. I have the 1924 Edition published by Messrs Cassel.
Note: this volume being over 75 years old is thus out of Copyright.
Ralph, we took a more practical approach than theoretical in determining these standards. Unlike Mr. Greenly–who was most decidedly a pioneer in model engineering, we have decades worth of practical experience upon which to draw. We could look at individual wheelsets from various manufacturers to see what works and what does not. We also had to contend with established industry trends, which were likewise built on decades of history. For standards to be adopted, they have to play at least marginally well with what’s already in the marketplace.
Besides, when you compare the NMRA proposal to the numbers Greenly writes about, they’re remarkably similar in most areas. That should not be a surprise, since presumably G1MRA based their standards largely on Greenly’s work, and these standards are based largely on G1MRA practice.
Kevin: Looks to me as if you have been a busy lad! Large Scale is truly hard to define. Standardizing wheel sizes within each of the different scales of LS is going to increase reliability. Thanks to you for taking LS experience to the table for this discussion.
You need to involve the manufacturers as much as possible. Remember they are the one’s that make the equipment. If they don’t buy in to what you propose then you have and will be wasting your time. Good luck on your endeavor.
Hi I have been involved in the railway hobby full size down to 3.5mm for50 years . The very basis of railways and indeed all engineering production is standards . The industrial revolution was started by people like Whitworth who brought in standards , infact war was the first user of standards with cannon ball sizes bullet sizes etc . Having spent 40 years in model engineering when , due to ill health , I started G Scale , I searched in vain for a set of standards , none ! Some trains derail on others switches half the buckeyes wont fit the other halfs ! What a total mess ! Thank you for starting the Standards process every G scaler will in time come to thank you , even if they are at first unable to initally accept them . We should then complain about the suppliers in these pages if they dont conform . Couplings or buckeyes should fit each other . I have spoken to two of the largest manufactures one said the dies are too expensive to change . Total rubbish select the best design then share the dies for those ones . Larger order , so savings there , two companies to pay for new dies when they ware out . Every body wins . Thanks to all the people who started the process ignore the flat Earth brigade
