I am just starting to run some of my rolling stock over a newly laid section of Peco Code 83 track, and have noticed that some cars run through turnouts better than others.
I have a few Proto 2000 8000 Gallon Type 21 Riveted Tank Car models, and they go through the turnouts just fine.
I also have an assortment of Con-Cor boxcars that visibly ride up over the plastic in-fill in the turnout frog, resulting in a very “lumpy” looking ride. It seemed to me that the flanges on these wheels were too deep, so I measured both wheelsets.
Both wheelsets measure 0.38" across the tread, but there is a small difference if I measure the flange diameter. The Con-Cor wheels are about 0.441", while the P2K wheelsets are 0.428".
I also have a few Athern ACL 40’ box cars, which are a bit in between - they measure 0.438", and show a little bit of wobble through the turnouts, but this is minimal. That small difference is enough to cause the problem, it seems.
So, the question is this - are the wheelsets both OK and the Peco flangeways too shallow, or is it just the Con-Cor wheelsets “at fault”. I put this in quotes because, unless I have misinterpreted things, they do conform to RP25.
If the latter, perhaps I should just swap out the wheelsets on the Con-Cor cars (I currently have half a dozen of them to do), in which case what should I look for as replacements?
Suggestions welcomed as usual.
Thanks,
Bob
