had to replace some trucks. Had some old metal trucks and replaced the brass and non-brass wheel with intermountain wheels. The wheels can move quite a bit laterally between the truck frames. Since the frames were metal, I was able to compress them in a vice a tighten them up. And since the trucks are metal, don’t want to use a truck tuner on them.
how much play should there be?
what are the drawbacks of too much or too little play?
Don’t have a hard and fast number, but there shouldn’t be a whole lot of play. The car will wobble, the truck may run skewed and pick points or frogs easier.
Problem here is almost certainly that the original wheelsets had longer axles. Best bet is to check Reboxx, their list is quite comprehensive and the actual manufactuer may be listed - but double check the old ones with calipers and go by your actual measurement. I know I had one upgraded and detailed former train set car that what they had listed in their chart for the exact make and model was way too wide. When I contacted them, they did note the error on their chart and it may be corrected now - that was 14 years ago.
Truck Tuner is definitely not designed for metal trucks. It may not damage the tool to use it on brass, especially if it’s hardened (not sure if it is or not), but it would quickly chew through soft brass for sure. Plus, if the wheels already fit too loosely, the truck tuner wouldn’t fix that.
You need some play between the side frames and the wheel. The differential effect is still in play with our models.
Too little play and derailments occur on curves and through the diverging side of turnouts.
Too much play and you run the risk of the wheels falling out of the trucks when lifted from the track and exaggerated bobbing from the cars.
This is a good reason to get an NMRA gage for the scale(s) you model.
According to my measurements; in HO, you should have about 1/32-inch (0.80 mm) of movement between the wheels and the side frames.
The easiest way to check is get a set of feeler gauges, slide the wheels to one side and check with the appropriate feeler gauge.
The distance between the inside of the wheel flanges need to be checked too.
If the wheels on the replacement sets are too close together this will appear to be excessive distance between the wheel and side frame.
Also the axle length has a factor. If the axles are too short; even with the wheels in gage, there will be excessive space between the wheel and side frame.
not a fan of replacing wheel sets if i have a problem with a truck i replace the truck , i did replace wheel sets that were too long for the truck frames resulting in cars that had were worse rolling than the start as the frames pinched the axles acting like a brake.
Is there any possibility he’d be adjusting endshake in sprung trucks by compressing something in a vise???
As in the prototype, you’d be using some kind of shim to adjust the positions of the sideframes relative to the bolster to control the distance between bearings. These might have to be very thin (or filed after installation to be very thin). Alternatively he could bore out the existing holes and fit plugs, perhaps of better bearing material like Delrin, and then use the truck tuner on those plugs to get the right surface finish and internal taper. I suspect few would notice if the ‘back side’ of such plugs is longer than prototype hub liners or cartridges, to suit shorter axles.
i purchased a car from ebay. Built by Revell (?). it had plastic wheels. I broke one truck trying to remove the wheels. The wheel was shouldered. So i needed to replace the truck because one was broke and the other had plastic wheels. I had the spare trucks and tried using them
i built an adjustable ramp with a 1/4-20 screw I could turn by hand. I measured the grade on a bunch of my cars by counting the number of turns. (7 turns with a 36" length is ~1%)
the best car rolled with 0.5% grade. an accurail boxcar. Most accurail cars were < 1.5%.
one car seemed to have problems > 3% (don’t know the manufacturer). I had replaced plastic wheels with proto 2000 wheels years ago. the truck tuner and some teflon lubricant didn’t seem to help. Replacing the proto wheels with intermountain made a big difference (1.75%). The proto wheels had some play. the intermountain wheels are about 0.015" shorter. ended up with 0.04" of play. I think the taper angle may be different on the wheels.
is it the play or taper?
i re-examined the car with the replacement trucks. They didn’t roll until the grade was > 2%. when I remeasured the play, it was more like 0.035". So I tried to compresss the trucks to reduce the play. when I reduced it to 0.02" on both trucks, it rolled with about 1% grade.
based on this, it seems more than 0.02", 1/50" of play is not good.
my worst car is a walthers bax car car that didn’t roll until the grade is 2.4%. The truck tuner and some lub helped, so that it roll on a < 2% grade.
