Where is my Avatar?
Hello it’s the old Guy again.
I don’t know who I made mad but my avatar does not show up on my end. I had to get a new computer so the problem may be on my set up. Anyway all I see is a box with the red “x”. Can the rest of you see the Avatar?
Thanks
Lee
nope, no avatar.
click on right in profile box to set one up
Do not see it on my end. ckeck the graphic settings on your system also you should check your profile setings to see if they are still ok The new forum may have something to do with it.
bnsf nut, yours isn’t showing for me either,
the only one in this thread I can see are mine, bothe eagle avatar, and loco pic in signature,
I do not see yankee flyer’s or BNSFNUT’s avatars either. They are boxes with the red “X” in them for me as well. I have seen other avatars and my own default gray avatar {or lack thereof} so I know at least some avatars are showing.
Perhaps you should go to “Public profile” on the right and click the "(Edit)" button and click to update your profile and re-install your avatar.
I can see mine where it says edit profile on the right side of the screen. Someone had a on post on having the same problems with Windows 7. I did not follow up on it but you may want to check it out to see how it concluded. It may be a server or security setting that may need to be changed.
Eureka, I’m Baaaaaaaaaaaack
Thanks
Lee
