Looking at where to put a layout in my apartment so I can start planning the benchwork, I am left with two choices, (a corner of the living room, and a corner of the spare bedroom), and it made me wonder, "where does everyone else put there’s?
I have heard of other layouts, like one of my options, being located in a spare bedroom. I have also heard of them being built in an attic room, in the basement, in the garage, and heck even in a large shed specifically built to house the layout with electricity and full HVAC.
Mine Ho regular one is in a spare Bedroom wiht a bunch of other junk- our “storage room”.
The under-the-table-top-Xmas-tree layout occupies a corner of the Living Room as we are building a newer bigger one than we had and it hasn’t been taken down yet. {the tree has}
If you are in an apartment, pick a spot you don’t seem to use that isn’t in the way and locate it there.
I had a pole barn built for my layout, my layout is 4’x78’x24x78’ it’s a U shaped layout that follows the walls with a 6’x50’ island in the middle. I had the barn built with total HVAC with humidifer and I keep the temp at 71 year round. I had a drop ceiling installed with indirect lighting to have a even light effect without shadows. I have a 10’ wide mechanical area on one end of the building where I keep the small hot water heater, electrical panels and half bath and laundry tub installed plus this is my work shop for my equipment. I have a track that runs into a mountain and comes into my workshop so I can add or remove equipment and then run back out to the layout. When I was “retired” by the military I spent about 6 months planning my last layout and designed the building and layout with all the specs such as lights, outlets, HVAC, work shop, mechanicals and access from previous layouts I had and visited so I had a vision of what I wanted. I had the building built 5 years ago and I have the benchwork done, trackwork done, and about 2/3 of the basic scenery done: i.e. plaster of paris covering the benchwork. Plus making hundreds of trees to add to the layout later. I was going to put the layout in the basement but then realized I would have to give up things I wanted to do or have on the layout in order to fit it in my basement. So the wife got a new car and I got a new pole barn. I figured it was a good trade. My wife likes to point out to me from time to time that I spent more on the pole barn and benchwork than I did for the house when we bought it many years ago. It’s nice to go out there and just turn up the tunes and work on the many kits I have to build or applying more plaster to the layout. I run the trains on my layout and sometimes the neighborhood kids will come by and watch the trains so I enjoy a few operating sessions and the kids don’t care if the scenery is done. Most of the kids are 6-10 years
Mine used to be in a separate structure with heat and A/C.
When I moved, I brought the layout with me and it is now in the basement studio that I share with my wife (she paints). I have about 20 X 15 feet and it’s nice to not have to leave the house to go work on trains (like I did with the separate structure - sometimes wading through a foot or more snow). It also gives us time together, even though we are working on our own stuff. I just like being in the same room with her.
My double garage filler is in - the garage. No connecting door from the house, but the garage’s personnel door is about seven feet from the front door, a straight line under cover.
The only (minor) annoyance is that, since we follow Japanese custom, I have to change shoes to go into the layout room. That and, since I have a gas water heater in the garage, it can’t be climate controlled. Not a problem now, but in August the temperature is brutal!
Mine is in my (unfortunately) unfinished basement.
Knowing the drawbacks of this arrangement, I’ll gladly accept a donation of $50K to finish it, because that’s kind of outside of my budget at the moment. [:D]
The real problem is that local code requires that the garage has to have open vents through the exterior wall. Can’t close 'em, and no practical way to isolate the rest of the space. Putting up a wall in a garage violates local code.
Believe me, I flew several ideas past the local code enforcers - who shot all of them down.
Chuck (Modeling Central Japan in September, 1964 - in a Mojave Desert garage)
This is a room off our family room. I ask the wife if I could put a layout in the corner and she said yes. She did not say how far out from the corner I could come.[:-,]
Why or how could it possibly cost $50K to finish a basement to the level needed for a model railroad?
Install a drop ceiling and some good lighting, paint the walls and floor, partion off just those areas not associated with the train room (utilities, laundry, etc.)
Even in a large basement that should not cost more than $8K (or less) to do yourself or maybe $15K if you hire someone.
Well here in the Mid Atlantic, most of my friends layouts are in their basements, since most houses have basements, usually pretty nice ones at that.
But my layout is above my detached garage/workshop. The layout room is 24’ x 40’ and is heated and cooled.
I designed this building some 16 years ago as part of the restoration of our home. We have a basement, but the basements of 1901 Queen Anne houses are hardly the place you want to put a model railroad - the headroom in the basement is barely 6 feet.
In my pole barn I put the drop ceiling in myself, I rented a laser level that had a spinning laser that kept a line on the wall so I could mount the grid work. I saved about 60% of the cost to have someone install it for me. Took about 4 days to get it all done, but I wasn’t in a hurry and it came out real nice. I installed the lighting at the same time and finished the duct work for the HVAC. I did most of the electrical after the contractor installed both electrical panels. I farmed out the HVAC and plumbing and I was able to finished the inside of the barn for just over 27k but this also included indoor/outdoor carpet on the floor too that I had installed. Biggest costs were HVAC and plumbing.
When we began planning this house (built in 1999) I figured it from the beginning to have the whole basement for my layout.
The house was custom designed and built at a Modular Plant and moved onto the basement walls in October of 1999.
With all of the utilities up in the main house - this left all of the basement with no restrictions except the posts holding up the house.
I had an Office built off the one end of the basement - separate of the 25 x 75 main basement.
The Office has the stairs coming down in it.
The basement was built with no windows and all of the walls were insulated and drywalled.
A drop ceiling was installed and all of the flourescent lights are attached to the steel frame of the house above and are plugged into outlet boxes run with conduit (8 switches control all of the room lighting)!
The wall outlets have multiple circuits (Switched and non switched) so I can shut down the layout when I leave the room.
Two years ago I added a 16 x 16 room on the back of the basement and when I finally extend the layout into my Office - will have over 2500 sq ft of layout.
I figured that I would never be satisified if i did not do for this layout room size.
One thing about it - it is taxing my modeling skills
