Where to find L12 lamp for Lionel 253 Block Signal?
I am trying to find replacement lamps for a Lionel 253 Block Signal that uses an L-12 lamp in both red and green. If I can’t find the colored ones, I’ll settle on clear and color them myself. Everything that I’ve searched for so far have a rediculous price (like $3 per blub plus shipping). I guess that I’m used to picking up small bayonet or screw base lamps at train show for 50 cents but I haven’t seen any of the L12 lamps that has 2 small pins projecting from the base. This is the same lamp that is also used in the Lionel 195 Floodlight Tower.
Hennings list them for $1.25 plus shipping.
http://store03.prostores.com/servlet/henningstrains/the-PARTS--dsh--Bulbs/Categories
http://brasseurelectrictrains.com/
Dave,
In your state.
Take care,
Ralph
Dave,
Also, Olsen’s in Ohio.
http://pictures.olsenstoy.com/searchcd31.htm?itm=273
Ralph
L12 and L19 bulbs are both 2-pin base bulbs. They are obsolete, difficult to find, and expensive.
I am not surprised at the prices quoted on this thread.
Thanks to everyone for the help. It looks like Henningstrains has the lowest price, although with shipping the price really adds up. But for an obselete lamp I guess that I’m lucky to find them at all.
Hi, Brasseur’s in Saginaw has the equivalent L12. They are 12-301 Red & 12-302 Green. Red is $4 and Green is $2. George
Check around for prices on ten packs.
Sometimes you can get 10 for just a little bit more that the price of 1.
Then you will have a lifetime supply.
www.ttender has them for $1.75 not sure if clear or colored but saw them listed for $1.75 and you might ask bulk price and how many for bulk
I don’t think Jeff sells bulbs in bulk.
Try Charlies trains or Ralph the Bulb guy.
Jill Sisco sells 2 pin bulbs in lots of 50, all her other bubls go in lots of 100.
Then there is Town and Country Hobbies.
All good folks with whom I do business.
One other option for replacing the bulbs in a 253 would be to use LEDs. They should be able to be inserted into the existing sockets without any modification. All that would be required is a diode inline with the common terminal clip and a resistor inline with with each remaining clip.
