Where to get and how to use a Relay that Counts the laps a train makes
I want to have two trains run on same track ,which I know how to do. But I wanted to expand this concept by having a train sit in a siding while the other train makes 3 to 5 laps. After the 5th lap, I want this train to release the parked train to make a lap and then return to its siding and start the mainline train again. I remeber reading an article in CTT where they briefly talked about using a lap counter on a desert layout but they didn’t get into great depth on the subject. Any help would be greatly appreciated.
Your best bet would be to contact http://www.digikey.com/ or http://www.allelectronics.com/index.html
I don’t know if you could get a counter to do that or not.
It would have to have a settable trip and a set of contacts.
One thing you could try is a timer relay in conjuuntion with a 153 IR controler.
Set the 153 IR up on your layout to trip the timer which would be set for however long it takes to make 5 laps.
Another idea would be to try http://z-stuff.net/ they have a few different stop start modules.
I have an idea on how it can be done with relays, though it will take a few. You could use the relays to count the laps. Each lap a relay is “latched”, when the last relay is latched, it stops the first train, starts the second train, and releases all of the relays, so the process can begin again.
This is a little complicated, and I’m sure there are easier ways, but my question is why count laps? There are a lot of interesting things that can be done with relay logic and automation.
Sounds like the job of the engineer. What happened to your engineer?
Charlie
Charlie, automation is a really cool concept for people who just want to sit back and watch their trains go around. I have done a lot of it in the past, and it is way more fun than simple circles. It can be a real challenge to get it right, but once you do, there is a great sense of accomplishment.
My new layout will feature computer controlled automation on the mainlines, allowing either the computer or a human operator to run the trains.
RJ, here is a way to do what you want. I had hoped it would be simpler. Perhaps someone else here can improve on it. It uses 3 relays and an e-unit.
All three relay coils are wired the same. In series are the supply voltage, a resistor, the relay coil, a normally-open contact on the same relay, and ground. The supply voltage is twice the relays’ operating voltage. The resistors’ resistance is the same as the coil resistance and their power rating is such that they can safely handle the full supply voltage indefinitely. Each of these relay circuits can be turned on by momentarily grounding the end of the coil connected to the normally-open contact and turned off by grounding the end of the coil connected to the resistor.
First the simpler problem of just alternating running of the two trains. One relay is designated the “master”. One of its single-pole-double-throw (SPDT, or form-C) contact sets switches track voltage between the center rails of the two tracks of the siding. (I suggest that the main be powered when the master is off and the siding when it is on.) The master is controlled by two isolated running rails, or “control” rails, near the departure ends of the two siding tracks. Each control rail switches the master to the state that powers the opposite track.
Another relay circuit is designated the “slave”. It copies the state of the master, but not immediately. Another control rail far from the sidings grounds the common of another SPDT contact set on the master, which routes the ground to the side of the coil of the slave that causes it to switch to match the master. The purpose of the slave is to remember the former state of the master even after the master has been switched by the control rails on the siding tracks. A normally-open contact from the slave is in series with one of those control rails and a normally-closed contact is in series with the other control rail, so that only the control rail from the track on which a train is arriving can s
If you are using DCS, you can calculate the scale miles run and the scale miles of track that make the loop.
or, you can attach a string to a crossing gate that attaches to a weight that drops down to a calculator that adds one with each closing of the gate as the train goes round and round
I actually found the CTT issue that mentioned what I wanted to do. It is the May 1999 issue about their Desert Layout. The part I need is a Depotronics Watchman Micro I Circuit board . Whatever that is. Thanks for the ideas.
Well, if you or anyone else might still want to try it with relays, I have been able to get the relays down to two poles each:
First the simpler problem of just alternating running of the two trains. One relay is designated the “master”. It records which train has just arrived. The master is controlled by two isolated running rails, or “control” rails, at the arrival ends of the two siding tracks. The control rail on the main line turns the master on; the control rail on the siding turns it off.
Another relay circuit is designated the “slave”. It copies the state of the master, but not immediately. One of the slave’s single-pole-double-throw contact sets switches track voltage between the center rails of the two tracks of the siding. It powers the main when the slave is off and the siding when it is on. Another pair of control rails near the departure end turns it on and off, much like the master. However, a normally open contact on the master is in series with the control rail on the siding, that turns the slave off.
To throw the track switches, the two switches are wired together, in parallel. The anti-derailing feature automatically insures that, when a train departs, both the arrival and departure switches will be aligned to let it back into the same track. If the switches don’t have that feature, you can provide it easily with another pair of control rails at the departure end.
Thanks Bob, that sounds like the same concept that the depotronics circuit uses except without the e-unit and is probably alot cheaper than the 125.00 for the actual circuit.
one other way this counting could be done is to run the trains via computer and design a simple 1+1 loop in BASIC
I might just have to try that!!!
