I am building a 49 1/2" Long by 17 1/2 wide diorama.
Where is a good place to get 1" thick styrofoam board or foam board that thick that size?
Thanks,
Cowboyred
Thanks,
Cowboyred
I get my white bead board at Lowe’s.
Depends on where you live. Styrofoam is a little different than white bead board. I get mine at any big box supply store. I hear it is more scarce in the south. Foamboard does not come that thick and does not make a great base in that it does not like water. There is a product called gaterboard which at 1/2 inch makes a great base and I get mine at an art supply store. It is pretty spendy.
Welcome to the forums!
My recommendation would be to get a 2’x8’ sheet of 2" foam insulation (pink or blue). You can cut your base out of the sheet and use the remainder for hills, etc. I recommend the 2" as it would be self supporting at that size. If you have to get 1", get a 4’x8’ sheet and glue your base from two pieces, use cheap latex caulk as an adhesive. You should be able to get it at a local building supply store, though as indicated above, some areas of the country it is harder to get.
Second, I would recommend you get two 2’x4’ sheets of 1/8" masonite. Use one for your backdrop, cut to the appropriate height. It would come within 3/4" of each end of your diorama. The second piece I would cut into strips to use as a facia to protect the edge of the foam, it dents easily. You could leave the top edge straight or cut it to the contour of your diorama.
Good luck,
I would recommend doing a search online. it’s every where (even here in Georgia) you just have to look for it. Searching online well save your feet and some gas. Foam-board or insolboard
Lowe’s or Home Depot should be able to help you out. Up here in the Northeast you can find that stuff on the shelf year round.
It will be in the lumber section. If you ask, don’t call it styrofoam, it’s insulation foam board It usually comes in pink or blue.
I was just at Lowes yesterday to by 1/2" foam board for my layout. They have “Dow” blue styrofoam in the lumber dept. in 1/2" , 3/4" and 1" thicknesses. And about $11.00 to $12.00 a sheet (4 x 8) in my area.
