Which Decoder do I use for this?
Just purchased the two products below and need help recommending a decoder for each. Both items were purchased within the last 3 months and say “DCC Ready” on the box. I believe the CF-7 says something about a “9-Pin” type which I am familiar with. Thank you for your suggestions:
HO Scale Athearn RTR CF-7 Engine Product #89914 Decoder Mfr./Model #-___________________
HO Scale Atlas Track Cleaning Car Product #20 000 374 Decoder Mfr./Model #-___________________
For the Athearn, TCS T1A (no harness) will plug right in to the 9 pin plug, after you remove the ‘dummy plug’ currently in place. Simple install. Remove shell, unplug ‘dummy plug’, plug in decoder, replace shell.
Track cleaning car - nothign fancy, a cheap Digitrax DH123 or an NCE D13SRJ, just so you can have control over the motor speed, fast for vacuum mode, slower for the polishing heads.
Excellent. Thank you for the suggestions. I wish someone published a spread sheet type chart of all products and various manufacturers decoders for each product, but that would be a lot to track and manage!
Yes, because there are so many different decoders and thent here’s how do you define “fit”? For example, Digitrax has a drop in decoder for most of my Proto 2000 locos, but I prefer to install TCS T1’s and solder the wires myself. The T1 “fits”…
Another example, for the Athearn, if you don’t care about Back-EMF, you can get an NCE D13SRJ and it will plug in just as easily as the TCS T1. The D13SRJ you can get for under $12 each if you buy a 10 pack.
There’s just too many combinations and new decoders coming all the time that an “all time” list just isn’t practical. Each of the major manufacturers usually has a chart for their particualr decoders. TCS has TONS of pictures - pick your loco and they will likely have a series of photos showign which decoder fits in and how to do the install.
