One of my locomotives has sound that works while the engine runs on DC. This has me hooked. So the question for to all of you is do all of your engines have sound. The other option is to have only a designated few locomotives with sound and then take one of these engines into the consist to give the lash up sound.
“Get one sound engine and you’re hooked.” Yup, that sounds about right.
I bought a Proto 0-6-0 with sound, and then added sound myself to an Alco RSC-3. Next was an SW-8 switcher, which I found with sound at Walthers for $100. Then, it was a BLI Hudson, again purchased with sound.
I just finished adding sound to a trolley car, using a downloadable Digitrax sound decoder.
Next, I’ll probably look into adding sound to one of my GP-9’s. They don’t get much action anymore, unless, as you suggested, they’re consisted with the Alco to make some noise. I’d also like sound in my S1, but that’s going to be a tight fit. (The SW-8, a similar engine in size, needs traction tires to make up for the low weight of an engine filled with a speaker and electronics.)
The old, old, noisy Athearn F7’s probably aren’t worth it. They’re too noisy all by themselves. The subway cars can’t be heard, as they spend their days in the tunnels. The other trolley, maybe, and the other Geep will likely get sound in the future if the first one comes out well.
I have 6 with sound (DCC). 2 are BLI locos, one is a genesis set (yes, with the MRC sound), 3 are set up with various types of Soundtraxx decoders. That’s out of about 60 locos. Get more than 2 or 3 of these things fired up and it becomes more annoying than pleasant.
I’m DC also, and I have several BLI steamers with sound. Unfortunately, it takes so much power to get the sound working on these locos (they’re DC/DCC) that it’s impossible to run them with my non-sound DC brass locos (by the time the BLI’s are moving, the straight DC brass is rocketing around the layout like the Kentucky Derby), so I don’t use them very much, unless I’m planning on running ONLY sound steam. Unfortunately, none of the ‘sound’ locos are for the railroad I model (Rio Grande) so when I run them, I run them only as ‘loaners’ from other railroads.
For a sound system (since I do like sound), I settled on a ‘fixed’ sound system with speakers under the table and a Soundtraxx “Heritage Steam” unit. It’s very Generic, though a lot of special effects can be programmed into the unit. The drawback of course, is that the sound is constant and not moving with the loco. I haven’t really looked into it, but I’m hoping that some manufacturer will take pity on us poor DC’ers and come up with a tender-mounted sound system that will work. Actually, there may be one out there, I suppose with all of my other projects, that I haven’t really looked that hard.
But I do like sound–it makes the railroad come ALIVE!
I have one BLI 2-8-0 On30 with sound , its alright but if you look close the chuffs are out of sync. I also have the Bachmann Forney (On30) with sound it is much better to my ear. When the On30 4-4-0 comes out with sound I will get it most likely. Operating on other layous with numerous engines with sound can be a bit much. The volume must be turned down.
Well, I;ve got a Proto2000 E-8 in Pere Marquette, Heratige 0-8-0 in Harbor Belt, a PCM T-1, and a Big Boy with sound. There’s a pair of BL2s from proto that will get sound,l as well as a Spectrum George Washington Mountain, and a set of RF 16s that will have sounbd in the 6000A A-unit, and then will be plugged in the diaphrams to speakers in the trailing units so the sounds are spread and balanced, and I save mucho moolla in Sound decoders. There’ll prabably be sound in the Bachmann Daylifght soon too. And I’dlike to put sound into a berk for the Polar Express, when I get the engine. Ah, to dream
Goto DCC. Suspect your on the verge. About half of my roster of 120 are deemed to be getting sound. I have only about 20 I have done, and about 5 with QSI. If you want accurate sound and railfan at the same time, I would look into LoK Sound. Sound is very addictive. Even if the loco doesn’t come with sound equiped, I just take the loco to my LHS and he does the milling for me and advanced installation for me. You only put sound and DCC into “Good” locos. I will let you be the judge of whats good and bad. But to answer your question, Nothing but Kato’s so far and the Proto 2000 QSI’s.
Try easy. The easier it is to install, the more likely you’l do it. But consider too:
1)Which engines will you show if you have guests? (Family, friends, etc)
2)Which engines will you run the most? or least, if sound will bug you)
3)Which engines are the best, or least,detailed? A sound decoder will either be that last piece or the piece that saves an otherwise neat but maybe lower engine from a life of shop displays.
About half of mine have sound, and that is because I made sure this time I bought more sound units. All my steam have sound( a must IMHO for steam). I also believe that only one engine in a consist should have sound…most likely the lead engine. Any more and it can get on the nerves pretty quickly. If I have multiple sound units in a consist, I usually mute all but one. Sound can be reasonable if you shop around and if you can install yourself.
All of mine have sound. I just couldn’t do it without any more. It’s convenient when it is also a DCC decoder that is doing it because it all fits neatly into the installation and you get the benefits of DCC.
Having said that, I wonder if BLI I cashing in on their choice to go hard at the BlueLine market. It seems there is still a lot of DC out there (Why not? It works!), and now the DC world is slowly spiraling in their death throes toward sound, like moths…next they’ll want to try one DCC engine, and then we’ll have 'em. [:-,]
I started collecting locos in the early '60’s - so none of them had sound. About 3 years ago I bought a Lionel Veranda Turbine DC/DCC with sound. After trying to get the sounds by flipping the directional switch on my DC pack, I took the DCC plunge! I have since bought an Athearn Challenger, 2 Atlas diesels with sound and an Atlas diesel DCC with no sound. What a difference since getting used to sound!! It will get sound soon!! I have since then also gotten a BLI NW7, an Athearn MP15AC, and a FDT Trackmobile. If I could figure a way to get sound into the trackmobile I would!! It’s nothing but sound for me - someday some of the old collection will also get sound, but for now I’m keeping DC/DCC with a DPDTCO switch. [{(-_-)}]
I have none and it will remain that way. My train room is a sanctuary of quiet. About the only sound I hear is the click of metal wheels over the occasional gap in the rails.
ANd you know what, there’s something decidedly theraputic about that. I suspect I’ll run that way too. But it;s nice to have the option. ANd fior me, the quiet goes away when somethibng goes horribly wrong
About 1/4th of mine have sound. I would like to have all my steam engines sound equipped, I recently added the MRC Sounder to a Spectrum 2-6-6-2 and liked it; inexpensive, easy to install and good sound. With diesels, I’m usually running them in pairs so I find having one with sound and one without running together works out OK.
I’ve mainly concentrated so far on doing installations that were pretty easy, like Soundtraxx drop-in board replacements for Atlas engines. It takes up the same space as the light board, and finding space for a 1/2" speaker and enclosure is pretty easy.
