All-
I just picked up a new release Kato HO C44-9W and I’m looking for a combo sound/motor decoder that would fit the bill without the need for any modification. CAn anyone make a recommendation for me?
Thanks in advance,
All-
Thanks in advance,
From what I have been able to determine, a Digitrax SoundFX decoder for a Kato AC4400 should fit the GE C44-9W. I have one ordered now from Litchfield Station, and should receive it by the middle of next week and then I’ll know for sure.
Another option is to wait for the new SoundTraxx Diesel Tsunami that is to be released in an Atlas Locomotive format in a few weeks, and see if one of those will fit.
The Digitrax SoundFX board has LEDs for the headlight and backup light. Whether the Tsunami will also have the LEDs on it is unknown until it is actually released.
Consider joining the Yahoo SoundTraxx DCC group where they are discussing the new Tsunami diesel decoders.
http://groups.yahoo.com/group/soundtraxx/?v=1&t=search&ch=web&pub=groups&sec=group&slk=3
Litchfield has free shipping over $75.00.
I highly recommend the QSI Revoltuion-A for this loco. I just had my first experience with the Tsunami Diesel, and I cant say that I can recommend it. QSI just has too many features to pass up.
David B
i don’t know what it is, but when ever i see QSI i think quasi and always want to put modo on the end.
Cacole-
Did you receive the decoder? How did it work out?
No, I haven’t received it yet, but I received another item that I ordered the day after placing the decoder order – I received an invoice indicating that the SoundFX decoder has been shipped.
I’m with David M. Bedard on not recommending the Diesel Tsunami (or as one of my Italian friends calls it, the “Salami” decoder). I received one of them a few days ago and was very underwhelmed with the sound quality. Nowhere near as good as the steam versions.
From the picture on Litchfield Station’s web site, the SoundFX appears to be exactly the same size and format as the constant lighting board that is in the Kato C44-9W, even the placement of the LED headlight and backup light. The QSI decoder does not have the LEDs or the holes into which the motor contacts are inserted, so it would require a major rework of the Kato engine.
Actually, all that is required is to cut the motor leads short, solder on 2 short wires, cut off a bit of the front decoder mount “T” (the long part of the T interfers with the QSI board) and the rest of the install is very straight forward. The decoder will screw on (but use Kadee insulating washers between the screw heads and the QSI board to keep it from shorting the board). Just choose your favorite LEDs (or even better, use the ones from the stock board) and solder them on. Get the proper length for the LEDs by holding the DC board beside the installed QSI board. Line up the mounting holes and clip the LEDs to length.
FWIW, I dont recommend using the provided 1 inch speaker that comes with the QSI chip, rather order an 16mm oval speaker with baffel. Place it in the long hood under the light pipe.
Hope this helps.
David B
Thanks for that tip about the speaker. I have several oval speakers with enclosures. I’ll try fitting one of them instead of using the cutout in the bottom of the engine.
The speaker that you get for free is subpar at best…lots of distortion. Keep in mind that the Revolution has a 2 watt audio processor. It loves speakers with higher wattage.
David B
