WHICH TRACK WOULD YOU USE?
I DON’T KNOW WHAT TRACK TO USE OUTSIDE?
Of your choices any of them would be fine EXCEPT the Bachmann track. It will rust into nothing in a very short time outside. Other than that you need to decide what you want to model, what kind of look you want the track to have,what power options you wi***o use and most importantly how much you want to pay for track that is very similar to each other. With that said personally I like the Aristocraft for my line and they have a nice sale on track in January.
Regards,
Jack
I would think long and hard before I chose 332.
It is too big for any scale.
I use 250 on mains, 215 on branches and spurs.
Had I known about 215 12+ years ago, I’d have use it for all of the line.
Plus, I use aluminum, which in the shorter codes follows earth contours like 332 never will.
TOC
What did I use outdoors? LGB brass, back when I lived in Hawaii.
What will I use outdoors next time? Stainless steel
What do I currently use indoors? Marklin nickel silver (for my Marklin MAXI trains). Don’t recall the code, but its 250 or smaller, for sure. I do like seeing those large trains operating on smaller, more fragile looking rails.
I been useing aristo usa brass for five years now , stainless steel is more expensive.
so stay with what i have. ben
I have a lot of curves in my garden so LGB flexible 5ft lengths are the best. I use Aristo brass for straight lengths as it works out cheaper in the UK and screw joints save a lot of time… Only problem is Aristo brass takes more time tarnishing, stays bright too long.
Ian P
All Aristo track and mostly LGB switches.
Reasonably priced ,widely available and looks fine to me.
Bud
To give you an idea on size:
.332 in 1:29 = 9.62" high rail.
Now, for your era, go find rail that tall.
Aristo-Craft American. Just the same as LGB, but at half the price! Best stuff ever!
Never use Bachmann track outside!
If I had to use any regularly available track I would use Aristo 332 bt I would look into the joins more, I’m not satisfied with what i have in that direction.
But I don’t use these tracks i use our club track which is available here in australia, I bend my own track and cut it to any size i require and this is by for the best for me. I would only use LGB points (switches) as mine are all R3 and electric and the LGB action is outstanding compared to others I have seen.
Rgds Ian SH
I’m using the AMS code 250 flex track with Sunset Valley switches on mine, and have thusfar been quite pleased with it. (It’s been in the ground not quite two months yet…) But, the track you ultimately choose should be tailored to your specifc needs, and how much work you’re willing to put into laying it.
The code 332 sectional track, be it brass or stainless steel, has a lot of advantages in that you don’t need to buy railbenders, everything fits together without cutting and fitting (except in places like passing sidings and other specialized track features), and it’s certainly robust enough to withstand the test of time. With proper electrical conductivity between the joints, you won’t have any trouble with running track power, either. On the down side, the sectional track limits you to just those sections, so your choice of curve radii is limited, and you may feel a bit constrained when trying to move around obsticles that would get in the way, such as bushes, trees, and other things that cannot be moved.
Using flex track gives you the infinite ability to tailor your track plan to your exact yard conditions. It’s not without its own set of requirements, but they’re not difficult to work through either. A railbender is definitely your best friend, though, unless you’re securing the track to a solid sub-roadbed.
If you would, give us some more information as to what you’re looking to do, and we may be able to better steer you in a better direction.
Later,
K
03jtud,
I have used Aristo brass but for the next section I am adding I am planning on using Stainless steel. There have been several discussions about track on this and other forums that I have found most useful. You should be able to find a lot of information using the search function.
Jaime
AristoCraft aluminum code 332 track with AristoCraft stainless steel switches for me. Since I have live steam and battery powered engines no problems. Also my layout is tabletop which goes all around the back yard and much easier on the knees…
Cheers,
Eventually it will be AMS code 250 outside and Llagas 250 2 15 on the inside yard layout. the two will connect. I don’t trust my family around the aluminum track outdoors.
Any brass 332 is ok for me.
I mainly buy items on sale.
Since the best switch for the price is LGB R3, it is brass 332 only.
Aristo stainless for me. Unless you have something far superior I don;t even want to talk about relative merits!
I use whichever solid brass track is the cheapest. I’m aware that this seems a lot like the way the MTA would build a garden railway but I’m on a tight budget.
GP-9 Man,
And you’re probably way ahead of most of us. The object is to have fun; it does not really make any difference how many $$$$ you put into it, it’s the final result and how much fun you have doing it! You certainly should not be discouraged because you are limited to budget, it’s a matter of value recieved.
Aristo/USA straights and curves, LGB switches, they are the most reliable and trouble free.
