Which Type Of Track ?
Hello,
I’m doing an N Gauge Layout 10 x 7. I’m undecided in which type of track to use. Should I use Kato Unitrack or Peco Code 55. Kato is very expensive and seems to have limited accesories. The gray plastic roadbed seems to be a problem when doing a western scene and wanting to add a different color ballast to it. Is this really a problem?
With Peco Flex the problem I find is how to bend it to get the proper curves without kinking it. Is there a special way to avoid this?
Please let me know your opinion on which one I should use. If there is any better track out there please let me know also.
Thank You,
Louie
In my opinion, I don’t think there is one “right” kind of track. I feel it’s a personal preference of each person as to what they like best and what works best for them. I’ve got both Peco and Atlas N scale flex track, sectional track and turnouts on my layout and I have no preference, at least not for track.
As for bending flextrack, here’s how I do it and I’ve never kinked a piece of track yet. Mind you, I use code 80 track, which is more sturdy than the code 55 you are using, but the same method should work. You’ll just have to be more gentle and take a little more care. I hold the track in the centre in both hands with my thumbs on the ends of the ties on one side and my fingers on the other side, hands about 6" or so apart. I then pull the track against my thumbs to start the curve. The secret is not to go for the final curve in one bend, take it a little bit at a time. Then I slide my hands further apart and continue bending, repeating this until I reach the end of the track. Then I start over in the middle, making the bend a little sharper.
When you let go, the track will spring back a little. When I’ve got it to the desired bend, I mark the end of the longer rail even with the shorter rail and cut it off. Then I connect that end to the existing track, and ease it into the final curve on the roadbed using the same finger-thumb technique and pin it down.
It just takes a little patience and bending it a little bit at a time. Good luck.
…Bob
ATLAS is the best in all model railroading!!!
