I am having several whistle problems. I am using all tubular track and a ZW transformer.
Problem 1 - When I place just the whistling tender for my postwar steam turbine on the track and hit the whistle controller it works just fine. However when I add the locomotive it does not. The engine runs fine and even speeds up when I use the whistle controller. Any ideas?
Probems 2 - Last year I bought a new Lionel Winter Wonderland train set to put under the tree. I cannot get the whistling tender (with or without the locomotive) to work on my old lionel tubular track with the ZW. The engine runs, and speeds up when I use the whistle controller. The whistling tender does work with the Fastrack and transformer that came the set. When I swap out the new CW-80 for the ZW (still using tubular track), the whistle still does not work. The engine is AC, not DC. Any ideas?
Any and all suggesions are greatly appreciated. Thanks!
