This one is around 6’ long and is easy and light to lift. The armature was made of extruded foam. The Rubber Rocks were hot-glued onto it. Then Sculptamold was used to smooth and blend the edges and ends.
This is turning into a very informative topic. It would be nice if some ideas could be included for bridge abutments as well, wood and concrete , cement blocks etc . pictures would be a super bonus.
I build concrete bridge abutments from styrene sheet.
There isn’t much to them, really. Just flat sheet assembled to fit the bridge, with the overall size and shape estimated from prototype photos of similar bridges.
This one has additional retaining walls adjacent to the abutments, built from wood bridge ties or 1/8" square basswood.
Abutments and wing walls around this bridge were assembled from more stripwood. I think I used 4X12s, plus some bridge ties for the vertical bracing.
The abutment on the right side of this trestle is cribbing, again using wood bridge ties. More cribbing supports another track farther up the slope, and next to that is a stone wall that i carved into plaster with a utility knife.
cut some styrafoam to shape and cover it tightly with plaster gauze and put the color in the water for the plaster gauze and it will also save time for coloring it.
Here is a part of the ‘stone’ wall in my harbor, made from some pink insulation foam. I made the stone joints with just paint and some light scored lines with a dull point plus other ‘pressings’ to give a little texture to the individual stones. All the paint is done with cheap acrylic paints.
