You must have a defective VO1000- Any of the new Stewart Baldwins I have seen or used run smooth and quiet. My only problem with them is that they are a bit to light and had to use N scale decoder.
Bob K.
I have 5 Athearn sw7 and 1500, UP, WP,SP…
2 Athearn SW1500. Detail being added as per prototype. Directional lighting awaiting installation.
On another thread I listed my Athearn SW-7 as my favorite. I’ve had it for 25 years. It’s gone through 4 sets of brushes and been converted to DCC. Still holds its own in the yard. When I converted it to DCC, I soldered jumper wires from the frame to the trucks. This improved electrical pickup alot. The other side of the truck used the metal strap that ran across the top to get juice to the motor. It was replaced when the DCC conversion was done. I have since done all my Athearns like this.
I have a SP SW1500 and a WP SW7 (carrying an SW9 number).
I have probabaly 4 or 5 SW7’s, (Plus a couple more train show second handers waiting for rebuild) and I have no complaints! I painted one up as NKP 233, and another will be 239 , Both SW’s that my Uncle ran out of Toledo in the 60’s for the NKP. They run great if you keep them clean and lubricated.
I have a couple of SW7s - one’s an Amtrak example while the other’s from the Special Edition set they did a few years ago for the PB&NE steelworks line. Both run, though they’re not amongst my best Athearns - problem would seem to be that the flywheels are not big enough, and they both growl worse than the rest of the fleet. Having said that, I’m keeping an eye out for an undecorated dummy “Calf” unit to convert into a slug for use with the PB&NE example, as per prototype.
Yes, I run a 20 year old Athearn SW-7 custom painted as a local road CIW #88. It started as a ATSF cow and calf set, but the powered calf chassis found itself under the tender of a 2-8-0. Both are still running well, thank you very much.
I have 4 of them
A pair of SW7’s, one of which I just picked up today brand new from my LHS & one each of a SW1000 & SW1500
Gordon
Does this count? I have an Athearn fframe powered by Proto-West and a bod y I cant identify. It
s got a short pug nose. It did run on a stock Athearn frame, and ran quite well, but now runs smoother.
Art
I have a dummy Rock island SW1500 and a 60’s-70’s vintage Santa fe SW7. the dummy sits with a ballast train and the other one is in a box somewhere. Hopefully Athearn will make the SW1500 in the ready to roll line someday.
