Why did Amtrak choose position color lights? The original position lights still used by the Long Island Rail Road, at least to my untrained eyes, provide an unmistakable view of the aspect, with fog resistant color and brightness, with a clear shape even if the center bulb is malfunctioning (as PRR intended).
The position color lights just look like they can be easily mistaken. Surely it’s not because the center lamp would burn out sooner than all the others. LIRR seems to like them just fine the way they are.
The Amtrak CPLs don’t have (or need) a center light, and it was N&W (not LIRR) that had some PRR-style position lights that used color (red) to emphasize a ‘stop’ aspect. One point might be that Amtrak converted to high-intensity light sources (LEDs) that are also more reliable, and went to color aspects that as on the B&O have ‘two’ redundant means of conveying an aspect - on high-speed trains this is useful.
Not arguing that any of your points about the functionality of the PRR lights are not right…
B&O style CPLs were aqlready in use in Washington Union Station, so the crews were familiar with them. In one or the other of the Corridor Improvement Projects Amtrak surveyed operating employess and found a large preference for the CPL-style indication. Amtrak’s CPL aspects are similar to PRR’s PL aspects. B&O signals rely on extra amber and lunar white lamps with a single CPL head to show different aspects.
Amtrak’s Chicago Union station had (and may still have) PRR-style signals on both approaches.
PRR had hybrid position light signals on the Bernice Cutoff and other lines in the Chicago area. Proceed and Approach aspects displayed three yellow lights and Stop displayed two red lights aligned horizontally.
The position light signals on the approaches to Chicago Union Station were replaced a few years ago.
Don’t know how. Color position lights are easier to decipher at further distances since you can go by color and position. Many older PRR signals just give you an “approach ambiguous” blob of yellow light at a distance if they aren’t clean or aimed properly.
Have no idea why PRR had just the position lights but was told by an N&W old head that it N&W had color blind Engineers ( firemen as well ? ) at one time so the standard was position lights. Once medical requirements were changed as all engineers who were retired that division was converted to color position lights. Anyone with more info or was that just idle talk ?
I recall reading somewhere that the position lights mimicked the semaphores previously used. Not sure if this is any particular railroad or a generalization, but if true, does seem to make sense.
On the ‘true’ PRR position light signals all bulbs, in all positions were off white yellowish. With their transitions through various ownerships at various locations over the years various light positions have been colorized. Initially starting with the lights at the 3 & 9 o’clock positions being made Red. With the N&W having been controlled by the PRR during the 20’s & 30’s the PRR signals were installed on the N&W.
The B&O also began installing their Color Position Light signals during the same period of time that the PRR was installing their Position Light signals. With B&O control of the Alton during this period of time, CPL signals were installed on portions of the Alton. B&O sold the Alton in approximately 1942 to the Mobile & Ohio which became the Gulf Mobile & Ohio.
When I was in college in Bristol in the mid to late fifties, I saw only position light signals on the N&W there; I knew of the connection between the PRR and the N&W.
In December of 1959, I was surprised to see color position light signals on the N&W somewhere near Bluefield.
That would surprise me too. Did the 1967 N&W rulebook include color position-light aspects? (Turns out it did.)
PRR started trying red-for-stop position-lights around 1955, but I’m guessing no PRR position-lights were full color until Amtrak started converting them between NY and Washington-- around 1990?
Timz, I hav no idea; I have never seen an N&W rulebook. I do not doubt that when the N&W began using CPL signals that steps were taken to make sure that all concerned knew that these were to be observed equally as strigently as the position light signals were. I would say that a new rulebook was issued as soon as possible after, if not before, the CPL signals were installed.
PRR’s CPL’s as noted above were all yellow in the fifties when I started in the Signal and Communications Dept. By the early 60’s the two lens’s in the stop indication 3 and 9 oclock positions were being changed to red and the center lamps were being rewired to be dark for the stop indication. All the other lenses stayed yellow. Did the PRR CPL’s ever have green lens’s in the 6 & 12 oclock positions for a clear indication? I don’t think they did. B&O had red, yellow and green lenses on the main head and white lenses on the auxiliary heads.
Only some of them did – I think a relatively small number of ‘some’. (Where are remaining CPLs with this aspect?)
For those who are wondering, the lunar white aspect was 45 degrees left, in the two positions normally unoccupied in a CPL main head.
Remember also that lunar white was an essential part of a NONrestricting aspect on B&O, as the center upper marker had to be ‘on’ for a green main aspect to be taken as authorizing any speed greater than slow.
B&O had a number of non-signalled directional sidings on their double track territory. The Lunar White (Restricting) indication was displayed at interlockings for entrance to those sidings. Additionally, in non-signalled TTTO territory, the Lunar White indication was displayed as the Distant signal to interlocked railroad crossings at grade. The Pilot Lights (the marker lights above/below and/or to either side of the Main Head were not lunar white - they were plain white.
As info - the B&O CPL’s at Mexico and West Hump control points at Cumberland are being replaced this weekend.
It’s my understanding that sometime in the 50s the ICC declared that all absolute signals display a red aspect when displaying a stop indication. Of course the 3 horizontal yellow light aspect of PRR’s PL signals didn’t meet that criteria. The problem was solved by changing the lenses in the 3 and 9 o’clock positions and extinguishing the center light as described above.
Position-lights around the Newark NJ station were still traditional PRR monochome (no red) in 2008 at least. Most (maybe all) the PRR position-lights between NY and Washington were monochrome until 1990 or so. (Including the ones at some/all the new 1980s interlockings-- Menlo and Iselin at least. Phil too?)
How about LIRR-- does it still have lots of monochrome position-lights?
I didn’t mean to imply LIRR used the red lights, but rather that it was N&W that I recalled using color in “PRR style” position lights to add the reinforcement of color to the stop indication. Subsequent posts established that PRR had the same approach for a few years in the '50s… but certainly that didn’t get applied ‘everywhere’.
I cannot recall anything but pale yellow in any position light in the New York area the whole time I was there – including many places on the Island.
