Why not Roadrailer for the Crescent Corridor?
Roadrailer doesn’t require chassis to pickup and drop off containers and expensive terminals with gantry cranes to load/unload trains. I’m sure NS would have looked at Roadrailer, but why was it rejected in favor of double stack? On the face of it Roadrailer looks more efficient than double stack for domestic moves of moderate distance.
It’s a good thing that futuremodal no longer is a participant in these forums or this discussion could get really nasty. That being said, RoadRailer is an oddball technology that doesn’t mesh well with conventional intermodal operations. There is another thread that addresses these issues more thoroughly.
With the expanded Panama Canal opening, imported containers will be coming to East Coast ports in greater numbers. So it makes sense to go double stack, as domestic and international traffic can share one terminal, instead of building another for RoadRailer.
It might be fun to inject the RailRunner technology into the discussion at some point – that is intended as a spine container underframe rather than a van trailer. We’ve had a couple of threads over the years that discuss the logistics fairly well. But it might be valuable to go over the topic again…
The technology and the terrain are two things that come into it…but also market. Is there a pair or pairs of market, i.e. industries or industrial groups and far ends of a corridor or pairing(s) that would use and support the service?
What is a “Moderate Distance”?
Is there a specific application you can suggest where RoadRailers would be more economical that double stack? The NS has to put IM terminals in places such as Birmingham, AL. No one has ever come up with a way to effectively move ISO sea containers using RoadRailers. So NS would have to either forego the international business or put in container cranes.
If they’ve got the crane equipped terminal they might as well use it. It makes no sense to run RoadRailers through a terminal equipped with cranes for container handling.
The verdict, rendered by the market, seems to be in. Double stack yes. RoadRailer no. There may be some possible applications for RoadRailer type technology. If you’ve got an idea for such an application, would you please share it with us.
[color=blue]
Can Roadrailers be stacked? To my knowledge - NO.
Intermodal has become a operation of moving maximum commodity (boxes) with minimum train length. A 9000 foot double stack train can handle 280 boxes (containers) - single stacked it can only handle 140 (and a I am not referencing 20 foot containers in my calculations) . A Roadrailer, handling 140 53 foot trailers would be at least 7420 feet long (and probably several hundred feet longer once couplings are taken into account).
The structural integrety of Roadrailers does not mesh well with all the other aspects of existing railroad operations. To my knowledge, a Roadrailer train connot be shoved - should that necessity arise acount of engine failure (engines do fail - even when they are being used in premium service). I also don’t know the ability of Roadrailers to operate in mountainous territory with a high degree of curvature in addition to the grades - both ascending and decending.
[/color]
I don’t think the verdict is in yet… take a drive down I81 sometime and count the trucks. This ain’t in the bag by any means.
Don’t forget that trucking has one huge advantage: it’s SIMPLE. A driver picks up his load at point A and then drives to point B, where he delivers. It doesn’t get any simpler. The Crescent corridor initiative, on the other hand, is COMPLEX: it involves, shunt trucks, chassis, well cars, containers, gantry cranes, terminals, and at least 10 people verses the trucker’s one person to move that load. So what is the draw? We’ve heard that they want to take trucks off of the highway. But so what. Market forces have put those trucks there. Shippers only care about service level and price. Will the Crescent Corridor improve service levels over truck? I think not. So now all we have left is price. How much cheaper is moving a container this way verses truck? That difference in price and how the market values it will determine the success or failure of the Crescent Corridor, and not some grandiose proclamation about taking trucks off the highway. The people who buy transportation don’t care about that. Roadrailer might be a way to shave some cost by getting rid of the cranes and the bottleneck at each end due to loading/unloading. That’s important, because price is all they’ve got to sell with this. If it isn’t appreciably cheaper than trucking it isn’t going to make a dent in transferring volumes to the rails.
Don’t forget that RoadRailer is pretty complex too. The trailers must be specially designed to handle the drawbar forces of the locomotive(s) hauling a string of say 60 trailers. They also need to have a set of railroad wheels for each trailer, plus appropriate braking equipment. That all adds weight which reduces potential payload if they are to stay legal on the road component of the trip. While of course RoadRailer will not require gantry cranes or toplifters, it still requires terminals and shunt trucks to actually assemble the trailers into a train, and take apart at the destination. And simple containers are much cheaper to own than specially modified trailers.
RoadRailers may continue to operate in certain niche corridors where they can make sense, but overall the container has been found to be the more practical solution for general transportation needs.
If a bearing fails en-route, I wonder how easy it is to set out a trailer, or if the whole train gets held waiting for additional resources to deal with the problem. Does anybody on the forum know?
John
Hello,
I found this…http://www.railpictures.net/viewphoto.php?id=252829&nseq=4,
NW
That photo is showing the original wheel placement using the spread axle on the frame and carrying the rail wheel set. Trailers set up like the one on the left are now used
For a Mark V. What comes to my mind is this. Call a local towing company. The kind that tows trucks. They can send a tractor and a boom tow truck. Go to the grade crossing split the train. The tractor gets the trailer. The tow truck pulls the rail bogus. The rail crew puts the train back together. And everybody is merrily on their way! Thx IGN
PS What should be above. The tow truck gets the rail bogie. Thx IGN
On why container instead of road railer. As I have said elsewhere, if you have enough freight to run 50 or 100 boxes why not spend the money for double stack. Roadrailers biggest advantage is the low cost of terminals. The disadvantage is longer trains and at some point those longer trains take up more capacity then is available. The initial cost of double stack is more then terminals. One also has to check enroute clearances. That can get kind of pricy. Undercutting bridges and tunnels. NS did this thru Virginia and West Virginia. Rgds IGN
There is also the question of where to invest capital. Presumably NS’s marketing are keeping their present Triple Crown equipment busy earning money on routes that are particularly suitable. They probably could find markets in the Crescent Corridor, but this would require investing in additional equipment, and the capital funds probably are better invested in business more profitable.
Well, you certainly cannot double stack RoadRailers. But their structural integrity is fine.
You can shove them. RoadRailer trains can, and do, back up. They take mountain curves just fine. Both UP and BNSF operated a regular RoadRailer train for Swift Transportation (a trucker) between Seattle and LA. The trains went over the Tehachapi Loop just fine. BNSF also operated its refrigerated RoadRailer “Ice Cold Express” over Raton Pass on a regular basis without problems.
Set outs of bad orders are not a problem. The RoadRailer landing gear is designed to lower on to the rails. So you just crank down the landing gear on the railer behind the set out equipment, uncouple, then put the bad order on a siding and lower its landing gear. Then recouple to the train and raise the landing get on the railer still in the train.
There is a big problem if you have to pull the rear
The reason NS still has roadrailers is balanced marketing. They do not expand into a new market until they have loads at both ends of a route. Triple Crown is very careful to minimize the number of empty miles, so most roadrailers are loads. That is why NS/Triple Crown have been sucessful when other railroads haven’t.
Until the Cresent Corridor is “balanced” ie same number of loads in both directions, Roadrailers are not a viable option. McClellans triangle routing might work, if implemented properly, as Triple Crown is a trucking company, not a rail company. But even that most likely will require truckers to deadhead empty after each load.
Roadrailers travel down the track just fine, thank you. NS has been running them up and down the “rathole” South of Cincy almost from the beginning. Amtrak was able to run them facing front or back at 79mph when they were in using them for thier parcel service.
There WAS a Crescent Corridor Roadrailer train for quite a while. Conrail’s RR265 and RR266 (265 and 266 on NS) ran Allentown/Portside to Atlanta for about 15 years. The trains died when the main shipper quit - I believe it was Chrysler’s Newark DE plant.
DS requires big expensive terminals - so lots of volume in the lane is key. But, drayage is the enemy, so that runs counter to the “big terminal” requirment. Lots of small ones would be better. But big terminals can support very productive large trains.
With RR, you can have very cheap terminals, so they’d win the drayage war. But 140<<280, so they lose the train productivity war.
Then their is the whole issue of box utilization. RR boxes are more expensive than a container, so it’s even more imperative to keep’em full. Hard to do if you have limited service lanes.
Had APL not pushed stacks, I wonder if could have wound up in RR-land rather than stack-land?
Good points and a good question.
It certainly didn’t hurt double stack that it had a “Product Champion” pushing the concept. And don’t forget that APL literally bought a base of traffic when it purchased National Piggyback Services. Intermodal marketing companies were much more important back then and National Pig was the largest in the business. APL got westbound backhaul loads for its import containers with the NPS purchase.
But I think double stack would have eventually defeated RoadRailers anyway. The initial railroad to use double stack was the Southern Pacific. And the SP, like the NS today, was a single track railroad. That means they had to get the most out of each train. They were very limited in the number of trains that could be efficiently run over the single track.
Double stack allows much greater train loads. Since most of the North American rail net is single track, and there are some capacity problems, double stack provides a more cost effective answer than smaller RoadRailer trains.
I do not agree that double stack terminals have to be large and expensive.
