In the Trains magazine that deals strictly about locomotives it is stated that the ALP45DP has two Caterpillar diesel engines that produce 2100 hp each. The question is why? Two diesel engines in a locomotive means twice as many parts that can break down and require maintenance compared to one large diesel engine. So what would be the advantage of this design? EMD had the E passenger units that had two diesel engine, if this is such a great design how come no other locomotives until now - except for the Krauss-Maffei hydraulics - have been build with two diesel engines?
I assume also that you only need to have one going when you’re sitting somewhere like in a station to provide head end power and to keep things warm when the locomotive is idle. Saves wear and tear on the mechanical components, reduces air and noise pollution, and reduces fuel consumption.
Of course if it has a dedicated engine to provide HEP and the main engines can be shut down in cold weather like some CAT engines can (I personally don’t know), you can ignore my post.
Also even though twice as likely(?) to have a prime mover failure but will still be able to limp in at a slower speed to a repair or replacement location.
With an overall length of 21·8 m, the dual-mode loco is around 2 m longer than the electric version. Careful design of the internal layout and has helped to keep weight of the four-axle loco to 130 tonnes. Maximum speed will be 200 km/h when running under 25 kV 50 Hz or 12 kV 25 Hz catenary, or 160 km/h on diesel.
The ALP-45DP has a 4 000 kW rating in electric mode, and 3 134 kW on diesel. It has a pair of Caterpillar 3512C engines rated at 2 100 hp arranged symmetrically around the transformer and converter pack to balance the weight. The engines are certified to meet EPA Tier 3 emissions standards. A Trans-Tech pantograph is mounted above the rear bogie.
Amtrak didn’t let the GP40PH-2s over 90 mph. They weighed about the same. I would suspect Amtrak has not approved these beasts for 125 mph…
It should be a moot point. These locomotives are for taking “Erie” commuter trains into Penn Station. There are only a few miles where they’d be allowed anything over 90 mph anyway. However, if they want to use these on the ACES train, then it would matter.
The ex-CNJ geeps (4100-4112 ONLY) are limited to 70 on Amtrak.
All other diesels (PL42s, all other Geeps, and P40s) are limited to 100.
It is unknown if the DPs will be good for 100 or 125. Until the Multilevel IIs arrive in 2013 (that’s simply my estimate, no date actually annonunced), there are no cars good over 100, and we don’t even know if the MLIIs will be for 100 or 125.
And it has been explicitly stated that they will not be used on ACES due to contract reasons and the lack of cab cars owned by ACES.
The engines seem to me really heavy. If they do not haul 125mph-trains, why gear them for that speed? With a lower top-speed, there would be better acceleration.
The wikipedia article doesn’t mention an auxillary-diesel for HEP.
No Aux HEP motor due to weight and space confinements.
HEP drawn from main engines like the trans con Amtrak engines.
Max. Diesel power: At alternator: 4,200 hp (3,100 kW) intermittent, 3,600 hp (2,700 kW) continuous
At wheels with no HEP load: 3,889 hp (2,900 kW) intermittent, 3,350 hp (2,500 kW) continuous At wheels with consist: 3,084 hp (2,300 kW) while providing HEP for 10 MLV consist At wheels with consist: 2,950 hp (2,200 kW) while providing HEP for 12 MLV consist
Correct. Having three separate engines in the carbody (plus transformer and all other electrical equipment) would be absolutely rediculous.
The PL42s have a 4200 hp prime mover, and when HEP is being drawn, it’s somewhere a little under 4000 hp. It has no problem moving six cars (a PL42 with six MLs is about the same as a GP or F40 with six Comets).
The 3512 is not exactly a Lightweight motor either. It weighs in at around 18K Dry. They use 2 of these Beasts to move the Big Dump Trucks used at the Stip Mines and at the Oil Sands.
Beaulieu: That is a very important point that our posters need to remember. I had missed that feature myself. The reason for certifying the 125 MPH speed IMHO is for future use when more of the NEC is upgraded for higher speeds. It is very important for future fluidity that all trains be at least 125 capable on the north end as MARC electric is on the now on the south end. Upgrading the NJ transit passenger cars? That may be problematic unless new equipment is ordered. The SEPTA SL Vs are 125 specified but not yet qualified.
