Why were RDC’s not used in commuter service? As an example, both CN and CP purchased them, yet both used locomotives and heavy coaches in their Montreal and Toronto commuter operations. RDC’s were supposed to be a cheaper alternative to locomotive pulled coaches, and the bidirectional nature of the RDC would have made them that much more suitable for commuter work as well.
RDCs were new equipment, of fairly restricted potential use, and therefore would have had to be capitalized accordingly. It was from Budd, so expensive stainless expensively fabricated. Meanwhile, commuter service was turning into more and more of a money hole, and in those days there were no government commuter agencies to pick up the tab.
Meanwhile, here came the great die-off of passenger service. All sorts of E units and all kind of rolling stock was available cheap, and could be kept running with minimal expense to serve the mandated clientele.
I have read that a number of railroads were enthusiastic about using the early Alco 2400hp C-C in commuter service… but of course didn’t have either the money or the revenue prospect. Lightweight commuter equipment of striking design was developed by GO transit… note: Government of Ontario… and the EL got wonderful new engines and lightweight HEP equipment for them to pull. One of those trains compares handily with the RDC equivalent of at least 16 to 20 separate Detroit 6-110s and all the complicated doodads to make each car self-powered, MU capable, etc.
I don’t consider them particularly unsafe, no more than, say, Silverliners. ATSF swore off them after a wreck, but NYC found out that one could go 183mph on the stock trucks…
Most gas-electrics were built to haul trailers if demand warranted. That was emphatically not the case with the first-generation RDCs; I believe Budd went so far as to say any warranty was void if you ‘towed’ with them… even special lightweight cars. I often wondered whether using ‘trailer-towing-grade’ transmission coolers for the torque converters would let a couple of cars be towed with AEM-7-style initial acceleration… but I think if a number of railroads that really ‘needed’ that kind of economy could have done it, they would.
NYC and a couple of other roads did a somewhat GWR-slip-coach-in-reve
It should be noted that CN and CP used their RDC’s primarily in secondary and branchline service not unlike prewar motor cars. They were also in similar service on various other roads. As time passed, many of them did wind up in suburban service, especially on B&M on RDG.
The B&O used their RDC’s in commuter service at both Pittsburgh and Baltimore/Washington/Brunswick service. Additionally they used RDC’s for their Daylight Speedliner that originally operated between Philadelphia to Pittsburgh and when the service to the New York market was ended at the end of April 1958, the Speedliner operated between Baltimore and Pittsburgh.
RDC’s continued in commuter service into the 1990’s after the service had been handed off to MARC.
The CNJ operated RDC’s as part of its commuter fleet and they also covered the off peak runs during the middle of the day. Some of the RDC’s were second hand cars that the Susquehanna had used for commuter service before they got out of the passenger service. If you are asking “why didn’t they completely replace locomotive hauled trains?” the answer is cost. Commuter services lost money, but the ICC and PUC’s wouldn’t let them drop the service. The commuter lines already had fleets of commuter coaches that were perfectly fine (in their opinion) for hauling commuters. So why spend a huge sum of (borrowed) money to replace them on a money losing operation?
PRSL had a fairly unique way of operating its RDC’s. A six car train would leave Camden and at an intermediate point (Winslow Junction? Newfield?) it would split into three seperate two car trains to Atlantic City, Ocean City and Cape May. Headed back to Camden, the three trains would be recombined. They owned twelve cars, enough for an eastbound out of Camden and a westbound to Camden to operate at the same time. Pretty slick
Check out the New Haven for RDC services.
As many of the above examples illustrate, the RDC was best suited to “longer run, low volume” commuter service where no electrification existed.
If you couple too many RDC’s together you have to start considering fuel and maintenance costs vs a conventional loco and coaches consist.
I would the think that the PRSL example with a six unit train that then split up is the limit of that economy.
The B&O Speedliner was seldom more than 4 units and often only 3.
The B&O leased two RDC’s to the Baltimore and Annapolis RR in the mid 60’s to test the market for reviving passenger service from Baltimore to Annapolis. After the novelty wore off ridership did not even support the idea of one RDC. An ironic end for passenger service on an Interurban that litteraly built the southern suburbs of Baltimore.
One of my earliest train rides was on an RDC.
Sheldon
I rode a NYC commuter train out of GCT with a couple of EMUs hauling an RDC in 1969. I don’t remember sitting in the dark going thru the terminal tunnels, so lighting was provided somehow. The train pulled upto the platform with the EMUs in the lead, and then went thru a balloon track to reverse direction and out of the terminal as the EMUs were driving the train. At North White Plains, end of 3rd rail at that time, the RCD was uncoupled from the rest of the train, and continued on its way north.
C&NW briefly used three RDCs in commuter service but quickly traded them for C&O stainless steel coaches.
Didn’t DART (Dallas) run RDCs till 2017 for Trinity Rail?
CP did end up using RDCs in local or commuter service around Montreal, and in very large numbers. I’m pretty sure I saw a photo of a 10 RDC consist, but I can’t find it at the moment so this 7 car train will have to do. This is at Montreal West, either in commuter service or arriving from Ottawa.
http://www.trainweb.org/oldtimetrains/photos/cpr_self-propelled/9116.jpg
As Overmod mentioned GO took over CN’s Toronto commuter operations and introduced new equipment at a fairly early date (CN still had a lot of other passenger routes to keep their RDCs occupied), and their busiest Montreal commuter route was electrified and had its own fully depreciated fleet, using DC boxcab electrics and heavyweight coaches into the 1990s.
I remember the boxcabs… they were a Montreal fixture for decades…I guess the RDCs didn’t work out long term as most commuter trains were pulled by F units beginning in the early 70s… Perhaps bilevels pulled by conventional locomotives proved more efficient than RDCs, and likely these older locomotives could be purchased cheaply by the commuter agencies.
Some of this original GO equipment was self-propelled diesel cars. While not “Budd RDCs”, effectively the same thing. But they primarily went with diesel-hauled trains.
The Metro-North used them between Croton-Harmon and Poughkeepsie up until the early 1980s. You could see how the New York Central name above the windows had been ground away with a body grinder but it was still readable.
As Dude says, CPR heavily used RDCs for a while in Montreal. They had quite a large fleet, purchased originally for various branchline passenger services that were now history, and then redeployed to the Montreal commuter pool. I believe 12 cars was the record train length once or twice at Christmas.They mostly went to VIA as CP fought to eliminate that commuter money pit.
CN had a number of regional passenger services that were well suited to RDCs, especially in southern Ontario, once the head-end mail and express business left the rails. VIA took over those.
Commuter trains in Toronto were largely non-existent until the start-up of GO Transit about 1967. GO had a mix of new self-propelled cars built by Hawker-Siddley and coaches from the same builder hauled by GP40TCs. They soon discovered that about three cars were where the maintenance and fuel costs crossed for operating a train; for anything longer locomotive and coaches was cheaper. The self-propelled cars were converted to non-powered control coaches and continued expansion of GO Transit used only locomotives and coaches, eventually bi-level coaches.
At the time the bilevels were introduced the rumour was that the unique design at the ends was to provide a location for a pantograph should overhead electrification be introduced. I will leave it to others to comment on whether this would have been feasible.
John
Apparently the premise to my question is incorrect… RDC’s were in fact used in commuter service in Montreal and elsewhere. Interesting… I lived in Montreal for some time and wasn’t aware of that…likely before my time. To my recollection the bilevels used in Montreal were not tapered at the ends…the ones used today are, as are the new GO bilevels in Ontario.
Atlantic Central: I was in collage in the early 1960’s and after seeing an article about the Baltimore/Annapolis RDC’s, wrote to the president of that railroad and got a very nice letter from him explaining his ideas. I believe the fare was about 25 cents! As far as I know, that route is now gone. I also had a great nighttime ride on a NYNH&H RDC from Springfield, MA to Boston, very fast and very bouncy.
Yes, the northern part of that right of way is now light rail, the southern part is now a walking trail.
Sheldon
The original CN boxcabs were slightly younger than the BA&P boxcabs, sharing the 2400VDC electrical equpment.
For many years, RDCs handled the vast Boston & Maine commuter service out of North Station, Boston, exclusively. About 75 RDCs were used. Many survived into the “T” era, some ending up as regular de-motored coaches in push-pull service with locomotives.
But remember, a ten car train of self-powered MUs of any type takes a lot more maintenance and inspection time than ten coaches and a locomotive.
