I am a novelist, author of Yonders, Illinois (and some other books on motorcycling, but in Spanish) and I am describing something that I remember. It was in the early or middle sixties and I saw a passenger train on the C&EI coming form the north into Hoopeston, Illinois. I remember it had a roving, side to side light, I friend from Hoopeston who knows trains said he remembered it too and called it a wig-wag ditch light. Could this be true. My memory of it is vivid and it was something I had not seen on the C&EI or any railroad before. I don’t want to describe something in the new novel I hace begun unless I can be resonable sure it existed.
One of several types of ‘Mars Light’ or ‘Gyra Light’. Some railroads even mounted them on the roof of diesels aimed upward to draw attention.
Ditch light is a later development and the name, I believe, derives from Canadian railroads that had side-aimed lights to help see rock falls in the ‘ditch’.
There were many variations. Some had a fixed light source and a reflector oscillated. Some were red, or white, or both:
ATSF_mars by Edmund, on Flickr
If the train went into emergency the red light would automatically illuminate.
Some roads used red oscillating lights at the rear of trains. The Mars light traditionally had a horizontal figure 8 pattern whereas a Gyralight was generally a simple ellipse.
Cheers, Ed
It sure looks like the C&EI had Mars lights on at least some of its diesels.
You could always email the C&EI Historical Society to verify.
Source: ceihs.org
I’m surprised that Ed (gpullman) has not chimed in here.
Go back three days… (first reply!)
I love the look of Mars Lights. I camped out at
Roosevelt Road in Chicago at the Amtrak coach yard and watched a bunch of the Burlington commuter trains passing through with their Mars Lights on and illuminating the overhead bridges with the ‘wash’ of light. Really neat to see at night.
Cheers, Ed
Was that specific to the C&EI?
Kind of tough to decipher from a still photo but this F7 has its Mars Light illuminated:
Momence Monday by SE Delmar tower, on Flickr
That’s about all I can offer on the C&EI.
Cheers, Ed
With the information given by the OP that’s about all I can offer. Sorry.
Ed
Good enough. Thanks, Ed.
From observations over the years. Most carriers that used ‘Mars Lights’ on their locomotives placed them in the traditional headlight housing and then put the actual headlight on the door on the front of the engine. I imagine the operating apparatus of the Mars Light used too much space to allow the nose door to be properly opened.
Those are interesting observations. I am accustomed to thinking that the Mars was was usually placed directly above the headlight. I am not familiar with any other configuration.
Because the normal position of the headlight on E’s, F’s, FA’s, PA’s - without Mars Lights is the ‘high’ position.
Ahh, that makes sense.
Here’s a view you won’t find very often. The ‘business side’ of the Gyra light assembly. Obviously there’s extra bracing and wiring which precludes hanging everything on the door:
SLIDE08-PRESTON-COOK by John W. Barriger III National Railroad Library, on Flickr
This assembly happens to be on an Alco PA-1.
Regards, Ed
One of my favorite memories is riding through a lightning storm in a UP dome car across Kansas and watching the Mars light and the yellow strobe light on the lead E unit rounding the curves.
Mark
But did the C&EI diesels have Mars lights in the early to mid 60s? That is the question.
It has been pictured! It is so.
That’s what I thought. Thanks.
I have seen references – I cannot quote them specifically, though – that indicate the Mars lights and Gyralites were mounted as high as possible, which accounts for them being in the ‘headlight casing’. I am certainly aware of the problems with bracing, offset weight, etc. that would be posed by the light mechanism being mounted on the relatively flimsy nose door.
At some point in the 1990s, KCS experimented with a highly interesting version of this sort of light – it was a high-intensity beam set at an angle in a rotating housing, so it flicked 360 degrees per rotation lighting up everything in the weeds and overhead, with persistence of vision making it clear to see things away from the directional headlight (and presumably ditchlight, when those came in) beams. I only ever saw this installed on one locomotive, but the pattern of the bright rotating illumination patch was striking, and effective even seen from the back ‘far away’, at lighting up the surrounding area without blasting the neighborhood with floodlight photons…
I do not know if this was the same arrangement I came across late Sunday night, on KCS ex-Rio Grande unit 634. This has a conventional-looking lower nose headlight casing, but the two sealed-beam lamps are set at an angle and rotate together in phase, giving a bit of the impression of rolling eyes. The unit I remember had the rotating light in what would be the headlight position over the cab.
Canadian Pacific and I’m pretty sure the C&NW had oscillating lights mounted on or near the roof (or top of the smokebox) aimed upward. I guess in the fog they’d be OK but on a clear night?
I’ve been in a few engines with a Gyralight running in foggy weather. It really can make you dizzy and I imagine in the case of a tired engine crew, lose situational awareness.
Here’s the C&NW example:
CNW_400_Chi by Edmund, on Flickr
I seem to recall one of the New England roads also had a passenger unit with an oscillating light pointed skyward. The New Haven Comet, perhaps?
Cheers, Ed
