The CORP (former Southern Pacific) passes through Jackson County, Oregon, including the communities of Phoenix and Talent. The effect of recent wildfires in the area can be seen here: https://www.youtube.com/watch?v=56iXfglDCGo
On another forum there has been speculation that CORP will need to replace burned wooden ties. Question: when wooden ties burn, does the heat cause metallurgical damage to the rails, switches, etc.?
In most cases, no. There might be damage to the hardness of head hardened rail but I am not familiar with how that is done. The wear resistant parts of switches and such are usually manganese steel which is not heat treatable.
When I was working in the gun business it was axiomatic that if a gun ( rifle, shotgun, pistol) was in a housefire, and the fire was hot enough to burn the stock away, the temper of the gun steel was considered ruined and for safety’s sake the gun should be scrapped.
What a fire hot enough to burn away wooden ties would do to rail steel I wouldn’t know, but it certainly wouldn’t do it much good.
In a well constructed track the ties would be encased in the ballast structure. While it would not be impossible to have the ties catch fire - only the top surface of the tie is open to the air and sparks. The ballast structure should not have weeds and other agricultural growths able to catch fire. If ties were to catch fire it is possible enough temperature could be generated to play with the heat treating and tempering of the steel.
In any event, qualified MofW personnel would have to make a full inspection before train traffic would be restored.
We need to hear from someone who knows, but I’ve wondered before about the temper in steel rails when thinking about the white-hot thermite welds. I would guess that the temper is not something that is depended on for hardness or toughness. We had discussions years ago about NOT using a torch to burn holes in rails, apparently because of stresses set up in the steel, but in that case you have a local hot spot in relatively cool rail. When applying a thermite weld the rail in the vicinity of the weld is preheated so there is no sharp hot-cold boundary. Anyway, my point is that I would guess that temper may not be a factor. Again, we need to hear from someone who knows. (Calling Mudchicken.)
Depends how hot the fire was, how old the ties were and condition of the joints (lots of popped bolts etc - If you had weber joints with wood inserts, you are buying lots of new OTM)…Cimmaron Valley Railway had over 60 miles of track burn not quite 10 years ago (it appears they managed to save a majority of the rail, but they had severe OTM issues, especially joints and anchors from what I was told)
Slightly off topic. Are loco air filters able to handle all the smoke and debri or do they have to be changed more often?. How many different air filters on a modern loco these days ?
It means ‘Other Track Material’ – everything made of metal in the track, aside from rail, that might wind up sold as scrap.
A Weber joint is an odd kind of heavy wood reinforcement fishplate, used predominantly on ATSF. It is not meant as an insulating joint; it holds the rail ends in alignment while absorbing vertical shock and keeps tension on the rail-joint bolts. If you burn track containing these, you will need new joint bars – perhaps a lot of them – and probably different bolts and nuts and washers, all of which are supplied as OTM…
Buried in another thread is the original patent and some of the sordid history of the damned things. The wood was supposed to expand and keep the joints tight and rattle-free. Nobody tested the concept first. Failed miserably.
Out here in the arid west and southwest you will find them on low tonnage branchlines and in yards/backtracks. They are a labor intensive headache to maintain and replace. Funds the roadmasters rarely got to use to replace them vanished post-WW1 when it became obvious Webbers were a failure. General policy became remove them as they failed or when you had to remove the bars for any reason. I inherited a pile of secondhand 90# bars at Walsh, CO when I moved onto a new territory from another roadmaster with no explanation. I soon figured-out why.
I’m still wondering about the concern Flintlock brought up about the temper of the steel in the rails themselves. Would the heat of the fire affect this adversely?
Temper: Given that most ROWs are kept reasonably clear of vegetation (clearly there’s wide variations there), I’d opine that short of the ties burning, there would be little direct impingement of the flame on the rails. Just the usual ballast profile generally provides several feed of clear space.
Too, we have to consider the type of fire. If the fire is in dense underbrush near the ROW, there would be greater danger to the rails than a crown fire.
Another factor will be burning materials falling on the tracks themselves. If the ROW is kept clear (often 60-100’ wide) only the taller trees pose that danger.
I think I’d be putting any rail from a burned wooden trestle in the recycle bin.
Work hardened rail is incredibly tough stuff. I have seen stuff from from bridge fires wind up in backtracks after audigage and magnetic/ultrasonic testing. Like Tree says, it’s the decision after all the variables are considered.
(Conversely I tested some new 136# CWR over an inspection pit and found piped rail - removed that in a hurry and ticked off a CMO when his new new non-AREMA compliant toy was removed from service. Got in some hot water with my ChE for running the D-Car over the pit on a side trip.)
Mudchicken, I always appreciate your posts for the knowledge they impart, but you sometimes use terms that puzzle me. Does “piped rail” mean that it contains hollow spots? (Like a pipe?)
It’s not like they do it intentionally! Look up ‘piping’ defects in castings to see a similar concern.
If there is a defect in the ‘center’ of the piece of steel being repeatedly rolled into rail shape, you will have what amounts to an open crack in the center of the web that comes under enormous mechanical and thermal stress as the rolling and annealing proceeds. I(f you then put this in track and load it, expect the two ‘sides’ to buckle, as seen here…
