Have a wired tether MRC PRODIGY dcc system and want to convert to a radio control handset… one is offered which MRC advertises as compatible with my old system… any personal experience with such a setup would be appreciated…
Why not contact MRC for the correct, accurate answer? MRC has a few legacy products that are no longer supported. David B
Hi A,
Our club use Gaugemaster Prodigy, same kit as MRC but sold in UK. We have a Prod running 4 hand-sets and the plug-in wireless conversion. Not the stand alone wireless system.
1 transmitter/receiver is plugged into a high level extension plate and according to the dumf any number of handsets can be worked off it, particularly if you use a booster. We are only using the 1 to let kids have a go, outside the layout. With someone on the panic button, just in case.
Hope this helps.
Be in touch.
pick.
Contact MRC. You have to match the correct throttle to your system. I know they sell wire less conversions which I believe is a throttle and receiver. I know if you have more than 1 throttle, you have to make 1 the master and the others slaves. Joe
