Will removing the can-shaped capacitor destroy or silence a sound decoder?
Sometimes, it’s nearly impossible to replace the body shell of small diesels after installing a sound decoder and it’s because of the can-shaped capacitor. Can I remove the capacitor and not lose sound? I haven’t experimented because I’m not sure if I’d be able to re-solder the wires. So obviously, you’re dealing with an electrical novice. Thanks for the help.
Karl Sonkin
We need more info. SoundTraxx has sold a shrink wrapped decoder that uses a can type capacitor for the sound wire connection to the speaker.
The newer shrink wrapped and PC board type decoder use a can type capacitor for stay alive function which has nothing to do with sound.
I have those different type decoders. They come with diagrams and the decoder companies have diagrams if you take time to look around. I suspect you have the SoundTraxx decoders and the SoundTraxx site has almost all the diagrams.
Try to give more info in the future.
Loco brand, type, decoder part number, even a photo can help.
Removing that capacitor may not cause you to totally lose the sound, but it will probably be seriously degraded and the least bit of dirt on track or wheels will cause the sound to be interrupted.
Oh sure. They always put on extra parts that you don’t need. ----NOT----
Remove any electronic parts at your own risk.
