Hey…
I brought a Williams LV FM 109.
Its works well, but the sounds are not loud. I tried another Williams product GG1. and its loud. I think it might be because the the shell muffles the sound. Does any one else have this issue??
Thanx,
CS
Hey…
Thanx,
CS
You need to take the top off and look for a small volume style switch inside on the circuit board and you can adjust the volume with a small flat tip screwdriver, at least on the F-7’s that is what you can do. If that don’t work maybe you can drill a small hole, under the speaker(remove speaker first), on the bottom of the frame and that may increase the sound.
Lee F.
Hey, I took off the shell/cover. Looked for the switch/screw, couldnt find it… What does it look like?
The shell doesnt have any holes to let the sound out, so you are right about finding a way to opening up some holes.
I appreciate your help,
Thanx,CS
