Window art & signs
I have posted over on Photobucket most of the collection of “window art” that I have used.
http://s269.photobucket.com/albums/jj50/tltrigg/Window%20Art/
I print these items on clear acetate, and glue the printed side to another piece of clear acetate and put into the window frame. Signs are glued to the side of a building. If you like them feel free to download and use as needed
If you care to donate, send me your pic and I’ll add to this album
That’s some good window art! My miners might have a place to relax after work! - Peter
Your miners are probably looking for the ladies that reside on my harddrive as they are most probably not appropriaste for viewing on this site.
In that case, I might then have to put the sheriff on watch for tonight! - Peter
Naw, that’s ok Tom, I have a few of my own. [:)]
Our hard water quickly obscures any viewing through windows, so I don’t bother with interiors, or even the neat idea you had.
How do you get the printer to work with acetate? I tried printing on thin styrene once and it just made a mess. Maybe acetate has more “tooth”?
The acetate I use is found at Office Depot, in the Avery labels section. It can be used in both laser printers and ink jet. It has a “smooth” side and a “rough” side. Print on the rough side. Ink jet takes about 10~15 minutes to “cure”, of course color laser is insta-ready. I don’t have a pakage or I would give you the Avery item number, sorry.
When attaching the finished product, I use Elmer’s Craft Spray Glue. It will not make the colors run like most other adhesives. After printing I cut out the “artwork” and a piece of clear slightly larger than I want. Spray the “ink side” of the “artwork” and let it setup a bit then attach the second piece. I let them set for about 2+ hours then trim to size with razor blade and straight edge.
I amend the previous post. Went by O.D. today to pick up some more for window decorations (Easter) and found they no longer carried the “Avery” transparencies. They did have “Great White” transparencies. SWMBO reminded me that we had been using this brand for the past two years. She had the old packages to prove her point.
Info:
Brand: Great White, Inkjet Transparencies.
Item number: 86999. U.P.C.: 7-80366 86999-1.
www.gwpaper.com
1-888-GR8-WHITE.
Every year we (the wife) select photos from the previous year (or years ago) to print on the transparencies and decorate the windows for each of the holidays. We started this “tradition” some 20 plus years ago using regular copiers (Xerox) for b/w prints.
SIGNS!
http://cs.trains.com/TRCCS/forums/t/162879.aspx
http://cs.trains.com/mrr/f/11/t/162879.aspx
