I bought 14 gauage wire from HD to use on sidings and lights on my 12x7 layout w/ DC. Is 14 gauge too thck? If, so what gauge to use? I thought to have different color insulated wire so I differntiate between the wires.
TIA~
~Lee
TIA~
~Lee
Wire can never be “too thick,” but 14-gauge is pretty hard to work with. For track feeders and general structure lighiting, I use #22.
For a DC layout, 18AWG or 20AWG is plenty for track wiring because you are only running one or two locomotives at a time on any given section of track… Lights can be on 22AWG.
If you are planning on converting this layout to DCC later on, then you could consider using 14AWG wired up as a bus system for the track with 22AWG for track feeders to the bus. 22AWG will still be OK for lights on that size layout.
