Does anyone know if there are smaller plastic clips to retain wires on decoder boards. I have just changed out an Athearn board for a new Digitrax DCC board and the pins on the Digitrax are so small the plastic clips will not hold. On comparing the two boards the Digitrax pins are about half the width of the Athearn pins.
I thought the retaining clips were ment to remove the necessity of soldering, in this case it doesn’t seem to have worked.
Whenever disturbing those clips for any work, I will solder the leads. Even w/ average soldering skills it should be a simple task. A few times I’ve experienced connection troubles w/ reusing them, even w/ proper tinning of the lead.
Thanks guys, soldering is not a problem for me, but again we find built in obselecence and something else to throw away. Still I guess it saves on the de-soldering.
