I’ve come across a supply of twisted-shielded wire. It’s two-conductor stranded, maybe about 20 gauge, with a third uninsulated shield wire and foil shield arround the two insulated, twisted wires. Does anyone know if this is good, bad, or indifferent for use with DCC? I haven’t figured out how to terminate the shields yet either.
I am currently building a DC layout, but eventually, I might convert to DCC. I am planning to use isolating track joiners on both rails to create blocks. I’ll wire feeders for each block back to the front of the layout to switches for cab control. If and when I convert to DCC, I’m hoping to turn on all the block switches and use the existing feeders to connect the DCC booster(s) to the track.
agreed. It will be a great source of feeders but its not large enough for your bus. You should use at least 16 guage wire for a DCC bus IMO, personally I use 14.
14 gauge for bus and sub, and 22 gauge for feeders. All solid wire, too. I’m wondering if braided/stranded wire might be easier to tin and to get attached to the sides/feet of rails…I expect so.
