To avoid them draining power from the buss lines, I was told that I can add a separate set of buss lines. They would then connect to an Athearn DC power ppack. If this arrangment is valid, what terminals on the powerpack to connect the wires from the groundthrow?
No, that is not correct in this case. You want to use power from the DCC track supply becasue you are routing track power through the ground throw. It is a DCC signal. Regardless, the ground throw does not draw any current so it is not a drain on the DCC supply.
And whoever told you that is causing unecessary confusion. Wiring the Caboose throws that have contacts to power the switch frog is EXACTLY the same for DC or DCC. The wire to the frog goes to the same conact on the Caboose throw in all cases. The Feeds from the left and right rails goes to the same contacts on the Caboose throws regardless if the track is powered from DC or DCC. The overall concept is no different - the contacts are used to connect the frog to one reail or the other, depending on which way the points are thrown using the Caboose lever. DC, DCC, HyperMagicPower, it doesn’t matter, it doesn’t change the wiring.
ANd the contacts are a simple electrical switch, there is no “current draw” unless one of the loco wheels or the wheels of a lighted car are actually on the frog in question. Really, I wonder where people get such strange ideas.
