Wiring Crossover Switches using DZ-1000
Can I wire both switch machines to one controller to throw both switch machines at the same time?
Thank You Dennis Sylmar CA.
Stock up on school glue when its on sale
Yes, its not a problem, you will probably need to experiment a little to get the switch positions coordinated with the LED colors. Also, remember you can relocate the switch machine to 3 different locations which will also help in accomodating the desired results.
Thanks for your answer. I figured you could but did not know for sure.
Dennis Sylmar CA
If getting the lamp colors to match routing is a problem the LED’s can be switched. Just pull them straight out and reinsert them. There is a flat side on the LED that “keys” them to the correct insertion.
