nsrail man,
I am a long time Zephyr user myself, and I’m not quite sure what the problem is. There are, however, some questions:
What is the gauge of your wiring? I use 14AWG for a 200’ run for my main track buss with 20AWG track feeders (keep these reasonably short), and my locos aren’t crawling even at the furthest point on my layout.
How large is your layout? Mine is 25’ x 50’, and I have no problems with low loco speed.
What kind of locomotive in what scale with what kind of decoder? I have most kinds of locos in HO (Atlas, Kato, P2K, P1K, Bachmann Spectrum, Athearn, Overland, etc.) with mostly Digitrax decoders.
Also, what do you consider normal/proper speed? I know my old HO club’s DC throttles were 18v, so perhaps the issue is that the locos are slow only by comparison?
One final point…check the brake feature on the Zephyr. The brake is between forward and reverse on the toggle, and has a small green LED next to it. When you are running and your engines are crawling, look at this LED. If it’s blinking, you’re in brake mode. Turn the throttle all the way off, make sure the toggle is all the way in forward or reverse, then reapply power with the throttle. This should cancel out the brake.
jktrains,
You never miss a chance, do you? I swear, it must be in the NCE manuals that if one buys NCE one must go out of one’s way to make diparaging remarks about Digitrax products.
FYI: The Zephyr usually comes with it’s own power supply (PS315), at least for the US market.
Oh, and maybe there are no PowerCab threads because so few people have bought them? [;)][:p]
Paul A. Cutler III
Weather Or No Go New Haven
