Wiring panel lights with push buttons?
I just needed to replace an above table switch Atlas # 585. All of my Tortoise turnouts have lights set on the panel.
The #585 has only three wire coming from the motor and no other terminal on it. I have no problem connecting this to the panel but I would like to add panel lights to show the direction the turnout is thrown. I have push bottons on the panel now but I also received a gift of an Atlas Controller.
If you can show me if the lights can be added and a picture of the connection it would be greatly appreciated.
Harold
You will need to add a Snap Relay. Wire the relay in parallel with the snap switch so the same panel buttons operate them both at the same time. The Snap Relay is like a switch, so you can use it to wire the panel lights to.
Harold,
Rats! I wish you would have said something, I would have stuck a wiring diagram with it. Like has been said, you need a Atlas #200 Snap-relay. But it does more than just panel lights, signal lights at switch and also power the frogs, you can use a latching relay, but for you the snap will be easier. They come with very explicite wiring diagrams, on how to wire all of it. They used to be about 7.50, but I believe they are double that now.
http://shop.atlasrr.com/p-51-snap-relay.aspx
Send me a E-mail,if you need help.
Btw: I like your trestle.
Frank
I have a bunch of under the table switch machines from Atlas that have those connections I have replaced with tortoise over the years.
Show diagram of how you would wire these to operate that turnout. The #585 is already installed and as I said has only the three wires and no terminal connections.
Harold
Harold,
Look at the back of the package that the #585 came in, there is a wiring diagram on the back of it, if you want to use the Switch control box. And if you want the control box at your control panel, add wires onto the wires that come out of the switch, to the control box. The red,green and black wires on the 585. But like has been said, you will need a Snap-relay if you want control panel lights and that comes with a wiring diagram.
I will send you a wiring diagram in a E-mail today, as a attachment, when you get the e-mail, double click on the attachment and the diagram will show.
Frank
Thanks Frank
With the weather up your way I just got the package Saturday. Already installed and working fine.
Harold
Harold,
I just sent you by E-mail, two wiring diagrams, for using control panel lights with the Atlas #200 snap-relay, should you want to use them. Also how to power a frog, with them.
Frank
For about the cost of a couple panel lights, you can use block signals for turnout indication, and see at a glance, which way a particular turnout or route is set. In the photo, the green signal shows the switch is clear for the main, and the red signal, also hooked up to the same Atlas relay, shows a stop signal for the yard lead.
