I am new to model railroading and am in the process of building my first HO layout. I have set up some track in a simple 15 foot loop just to get my feet wet. I have laid the track, put in a couple of turnouts and soldered the rail joints. I am using a simple 1 engine controller that I have wired to the track, again just to test and get my feet wet. I am using 14 gauge wire from the controller to the track.
While testing, I have run into a problem. The engine will not move without being gently pushed to get it started and when it gets about half way around the loop, it slows to a crawl and the light dims, even with a full throttle. Once the engine starts moving again, it goes half way around the loop again and starts to crawl. This happens with more then one controller and with more then one engine I have tested. What have I done wrong?
