Hi,
I am in the process of building my first permanent layout and I have decided to use DCC. I have already purchased a Digitrax Super Chief and plan to use radio control. My layout is 19’x23’ with a 10’ peninsula “around the room” layout for continuous running. I have also purchased the wire for the track bus and feeders and am about ready to install. However, this process quite frankly scares the wits out of me, because I know next to nothing about wiring and electricity. But I want to do it right so that my layout runs smoothly. So I need help. I have searched this and other forums for information but I’m a bit confused.
Do I run just one set of bus wires continuously around the room, or do they need to be divided into sections for multiple power districts?
What do I do with the end of the wire furthest from the controller?
Does the bus connect directly with my Digitrax system?
I’ve seen some mention of using ordinary light bulbs to isolate shorts. How does that work? Do you recommend this?
I apologize - I know for most of you that these questions are elementary and they have probably already been addressed. But, as I said, the more I read the more confused I’ve become. Thank you in advance for your help - and for those who do answer my questions, assume I know nothing about wiring…and you’ll be correct.
Pierce
