I built mine about 28 years ago from a centerfold in an MR magazine. As best as I can remember the plans either had dimension or I sized the timber to match the size of the timbers on the centerfold.
My LHS stocked Northeastern Scale Lumber and he had all the correct sizes. I built my trestle the same way.
Mel
In Paul Mallery’s “Bridge & Trestle Handbook”, there’s a chapter on wood bridges. There are drawings with the sizes of most members noted. It is an excellent book.
If you have a particular bridge in a photo in mind, the above will likely give you very good hints on sizing.
It looks to me that, if you had a nice drawing for a bridge that spanned 100’, and you wanted one for 200’, you wouldn’t just scale the plans up. They tend to add panels, also. You’ll note that the number of panels varies.
Anyway, I recommend checking Mallery’s book out. I have a 1976 copy, and I think I bought it not long after that date. I’ve read it cover to cover a couple of times since. And I pull it out once in awhile, for discussions like this one.
Spans much longer than about 30’ would require either metal girders, or a metal truss of kind, or a Howe truss if wooden. You would never see a wooden span of 100’ because the typically greatest length of timber in trestles and the like, the tallest bents, would be 30’.
I don’t mean to put you to the test, but would you be so kind as to provide an example of a 100’ wooden span that is unsupported with at least one central bent, pylon, pier, crib, or cables of some kind? I’m not talking about an arched structure, such as a road or ox-cart bridge over Ye Olde River, I’m talking about one with a supporting deck, at grade, that would withstand the mass of even a 60 ton locomotive midway along its span.
Thanks for those examples, Volker, which support my contention earlier…no simple spans, but spans with a Howe Truss or some other girder/truss arrangement. Even then, none of the timbers involved exceeds 9m in length, or if they do, by perhaps one more meter.
Selector is no doubt referring to “beam bridges”, the simplest of which is a log felled across a chasm. It is a single element or multiple parallel elements. Each beam is not fabricated or assembled.
He implied that when he mentioned soon after the term “a Howe Truss if wooden”.
This is a railroad beam bridge:
They are generally so small they aren’t even noticed. Until you put a bunch in a row and call them a trestle.
Girder bridges are a form of beam bridge (they are, of course, assembled. In their way). But I recall no wooden girder bridges.
We “all” know there are wood framed trusses longer than 100’.
Finding a 100’ wood beam bridge that will carry trains might just be more of a challenge.
I just overlooked Selector’s first post and therefore misunderstood his next one.
As a civil engineer (structural design) I wouldn’t even look for one.
Having seen lots of model railroads with the wrongly selected types of railroad bridges I thought I show an example (after misunderstanding the question).
It doesn’t happen on American layouts alone it is even worse in my country (Germany). But in the USA you have the luxury of a number of good books on the subject that we don’t have. Two were already mentioned here.
Regards, Volker
I did mean that you would never see a simple beam span of timber over about 30’ which was intended to support a 70 ton locomotive and several logging cars or ore hoppers. This is because trees used for timbers in trestles and other bridges don’t often go much further than 30 feet from nearest the ‘wide’ end until they start turning into cambrium and bark. So, when I began to research timber trestle construction years ago, it seemed that from site-to-site, and railroad-to-railroad, the longest timbers 12" x 12" on a side were about 30’. You can’t join such timbers to cover a 100’ span unless you use a truss of some kind. Most trestles that were long and had to span a river between bent frames employed a box truss, often of the Howe design. I have stood under such a truss that was at least 50 feet long, that being on the Kinsol Trestle on Vancouver Island. It is complicated and massive with many metal rods under tension. My guess is the Howe truss, by itself, would top out near 200 tons.
In your first post you state: You would never see a wooden span of 100’ because the typically greatest length of timber in trestles and the like, the tallest bents, would be 30’
Perhaps I misunderstand you again. If you mean that higher trestle bends are made of shorter posts of approximately 30’ on top of each other you are right. That is possible as compressive forces can be transferred over a butt joint. http://www.highestbridges.com/wiki/images/2/2f/CedarRiverTrestle3.jpg
The link shows the Cedar River Logging trestle in Washington State is 203’ feet high.
The story height differed from railroad to railroad. RGS had typically 16’ with a maximun of 20’.
We have all agreed that many rail Howe Truss bridges are wooden, and that other types of wooden trusses are suited for, and used for, railroads. In many cases their spans run much more than 50 feet. What we are attempting to settle is whether or not a BEAM bridge can have a span beyond 30-40 feet for railroad tonnages and still be made of timber. The answer is an unequivocal…NO. The span would sag too much in the middle and deviate from grade. That’s why we invented trusses…they are many times stronger, and can maintain their shape closely, even on long spans.
