I am about to put together my first wooden structure.
If I just want to stain the wood with an india ink / alcohol mixture is it necessary to first prime the pieces with some kind of paint primer?
Bar Mills for example had a tutorial that had the pieces first primed with a rattle can grey and then ink washed and then lightly sanded or wire brushed to give the facade more character and depth.
I understand that whatever I do I should ideally do both sides to prevent warping.
It is not necessary to prime before staining with the ink/alcohol mixture - it all depends on the effect you are trying to get. For “bare wood” look, straight ink mix is all you need. I have a few different color ink stains and use them this way extensively. One of the effects George Selios talks about in his FSM kits is to first stain the wood, then dry brush (say, with grey or white) to give a look of old peeling paint. Paint or primer followed by ink stain will give yet a different effect.
It may depend on the consistency of the wood. I usually just use a dilute ink stain. However, if you’re scratchbuilding and sourcing your wood from multiple places, you may find different woods take the stain differently. In those cases, a light prime coat will give you more even stain coverage.
Many years ago I ran across an article that suggested using steel wool in vinegar. I let it soak two days then used it on basswood and it really came out looking very good.
I always get a kick seeing all the little folks interacting in the interior of your passenger cars as well as on the layout. I love how each one is different. They are so well done!
If it’s a house, use spray primer for wood. Brush primer will go on too thick and wet and make thin wood used for structures to warp. I found this out the hard way. The problem with paint on wood is the wood is porous and will just “soak it up” causing the paint to be uneven, and wood to warp from moisture. The primer seals it and doesn’t absorb as readily into the wood.
For things like india ink and non even raw coverage is needed, just drop it on.
I owned and operated an interior painting company for years and doing bare wood in full scale is similar to modeling.
If staining, primiming with a paint primer will seal off the wood preventing the stain from penetrating. Plus, paint primer typically is white in color. Using a wood conditioner, a clear product specific to staining, will still allow the stain to penetrate, just more evenly. I prefer oil based stains over water based since water based may cause warping.
When painting a structure, a primer may be advisable, but again, waterbased primers and paints may result in warping so bracing is important. Most rattle can primers and paints are solvent based but warping might still occur so I still brace sections just to be safe.
