Woodland scenics light hub
I have been able to hook 2 WS lights to one light hub port. When I add a third, all,3 lights do not work. I assume thIs is a limitation of the resister that must be built into the light hub - right?
abbieleibowitz, I only use one WS light hub. I’m not an expert, but I don’t think a resistor would cause this. Hopefully someone smarter than me can tell you for sure.
Probably something to do with how you managed to wire them together into one port (i.e. series vs parallel). Three together may simply exceed the current capacity of a single port as well. Not sure the specs on it.
