Woodland Scenics Profile Boards
Does anyone use the Woodland Scenics profile boards on your layouts? If so can you share some photos of their use? If not why? I received some and I am not sure if I want to use them or not.
Google it and look at some of the images. Appears it is primarily used to provide a barrior wall. Perhaps the flat backside of a mountain?
Yes, was hoping someone else had experience with them or used them. I received some and I am not quite sure if I want to use them or not. Thanks! If I use them it may only be for a small mountain section.
MYVP Canadian Cascades episodes 29 and 30. They used it vertically, filled in the grooves in the bottom with foam and applied scultamold over it. The terrain they were modeling was vertical ridges running from top to bottom.
