Woodland Scenics Water
Has anyone used the new Woodland Scenics Realistic Water and Water Effects products?
How are they? Pros and cons? Advice or tips?
Hey there!
I bought a bottle of the “realistic water” and I can’t say I am overly pleased… I was only making a small pond but you’re only supposed to pour 1/8th of an inch at a time which took FOREVER!!!
Maybe I was using it wrong but I may not use it again.
Ian
I had asked a similar question on the forum a few months back and was encouraged to buy Dave Frary’s bible “How to build Realsitic Model Railroad Scenery” - noted on cover “water-soluble techniques that are quick,easy, and trouble free” I suggest adding this to your collection. I reviewed varoius web sites that use these techniques, and was quite impressed!
I have used both water products on my layout. I found them good, but I have no experience with other mediums. The Realistic Water needn’t be deep – an 1/8th of an inch is all it takes to look like deep water – with the base painted black to resemble depth. My first mistake was painting my “lake” to look like various depths and when I added the “water” it looked like something out of an atlas depicting ocean depths. I remembered hearing that I could paint over the “water” and after it had dried I painted until I thought it looked more realistic, then poured another layer of Realistic Water overall. As the “water” dried (several days) the surface changed to a “bumpy” look that everyone compliments me on for its realism – it looks like waves and water currents. I have no idea how I achieved that unless it was the way I used my gloved hands to “smooth” out the Hydrocal used to seal the Plaster Cloth base, or if it’s because there are multiple layers with paint sandwiched between them. I, too, like the uneven, more realistic look of the water surface. My only complaint is that I think somehow my lake lost the shallow color at the edge as the plastic dried and it now looks black all over.
I have a waterfall that feeds the lake and I used Water Effects for the falls. I first measured the length needed, then squeezed out toothpaste-like strips of the Effects side by side on a flat surface. Using a toothpick I roughly joined the “toothpaste” strips and let them dry – it took more than a week. When dry, I picked them up and glued them to my mountain outlet and “glued” them to the water surface with more “Effects” that I stirred up with a paint brush and toothbru***o resemble turbulence. I did that about two weeks ago and parts are still not dry.
There was no real odor using the products and I found them easy to use. Well… I found Water Effects really tough to squeeze out of the bottle. The Woodland Scenics video shows laying out the strips on a non-stick skillet that I did
BOTH HAVE BEEN USED ON OUR LIONEL LAYOUT, AND IT TAKES A GOOD 24 HOURS FOR BOTH TO SET UP,I DONT KNOW OF ANY CON’S,ON A LAKE IF YOU BUILD A DAM ON ONE END AND LAYER THE REALISTIC WATER LIKE IT SAYS ON BOTTLE YOU WILL GET A REAL WATER OR LAKE EFFECT,START WITH WAX PAPER,OR SOMETHING THAT WONT STICK TO THE WATER ONCE IT GETS HARD,EACH LAYER TAKES ABOUT 24 HOURS TO SET UP,FOR BEST EFFECTS>>>>>>>>>>>>>>AKA HUB
USE YOUR OWN THINKING ON HOW YOU WANT LAKE OR STREAM TO LOOK,THE GUYS THAT DID OUR PAINTED BOTH BOTTOM OF THE LAKE AND STREAM,I THINK THEY USE BLUE ON LAKE AND IT IS A LITTLE DARK,THEY USED A GREY AND BROWN FOR THE STREAM SIDES AND BOTTOM,AND I THINK THE STREAM LOOKS GREAT,ALSO ADDED SOME STONES AND VERY SMALL LOGS ALONG SIDE,GOOD LUCK AND HAVE FUN AKA HUB
