Work in progress: Wattsburg Station (quick & cheap techniques)
Folks:
First, the images:
Front:
Back:
Detail of brick:
This is obviously unfinished and a little hastily constructed. I have to build some doors, and install one window and lots of detail. The sign looks a little odd; I will probably handletter one large and photocopy it small. Computer lettering tends to look too stiff for old hand-painted depot signs (take a look at the Sussex sign in the old MR Easy-to-build Structures book to see what I mean).
What I am trying to do here is rediscover a type of scratchbuilding that gives good results for a minimal time and money investment. This building went together quickly, and the cost is about $3 in balsa, a few cents in glue and construction paper, and one sheet of Scalescenes brick paper, which I can print out ad infinitum (by mfr. license) from the file that cost me about $5.
The building is, as I said, built on a shell of 1/8" balsa. First the shell was made, windows cut out. Then the paper went on, creasing the corners and X-slitting the openings, then gluing down the flaps. Sharp creases are essential for good appearance. The bay is separately made, of the same materials, and applied after covering and window-installing. The roof is made of the same stuff by the expedient of measuring the center section, gluing, then sanding the ends level and cutting pieces to fit. Corners are braced with 3/16 square balsa.
Windows are inked with a black ultrafine Sharpie on the back side of salvaged pack-bubble plastic, probably HDPE, rubbed first with crocus cloth to frost it a bit. Curtains are white electrical tap
Looks good![tup]The wrap around brick on the recessed doors and windows turned out great.
Looks great, like the way you turned the brick course, of which really sets it off. Thanks for sharing…John
That building looks great; please post another photo when the window and door are in so we can see the final effect!
I have had similar success laminating computer printed color cardstock to masonite shells. I was able to reduce an actual photo of rock to serve as a stone porch and terrace - the effect is good.
Good luck to you - anyone who can outwit the vendors who want model buildings to cost as much as real ones gets cheers from me! Your approach can help make model railroading affordable again!
Nice modeling and way to pinch those bucks…Reminds me of some of EL Moores buildings years ago in RMC…Cox 47
