I have a HP Products TT scale 0-6-0 that I am trying to rebuild. The frame, boiler, and running gear are intact and in good shape, the engine is lacking it’s motor, worm gear, and cab.
The motor is a standard DC-60 with the commutator between the armature and permanent magnet, vice the other style of DC-60, with the commutator between the armature and output shaft. I have a Varney F-3 that I am planning on upgrading to have a pair of can motors vice a single DC-60, so getting a motor is not an issue.
The cab is easily replaced via resin casting of another HP Products steamer cab.
The problem that I have is trying to find where I could get my hands on a worm gear suitable for the task.
The local hobby shop does not like doing custom orders anymore, so I have a feeling I will have to use an online shop to get the part I need.
Does anyone have an idea as to where I could get said worm gear?
Here are some photos of the engine in question:
Here is one of my other HP Products 0-6-0’s after it’s restoration a few months ago:
I need the gear that attaches to the motor. The literature that came with a similar engine kit refers to this gear as the worm gear, and the other as an “idler” gear, that is attached to the shaft.
I am restoring the engine to operable status. If I am looking for the gear needed, then I am planning on making the engine operable. I do not see what the difference is between restoration and making it functional.
I need to borrow a friend’s tools to measure the gear pitch. I am right now trying to see what places might have the type of parts I need.
I have had a bad experience with NWSL and not getting the parts ordered, so I am hesitant to go through them again.
Here is some info from NWSL about gears. I have replaced gears in a couple Tyco steamers some years ago using the MDC gear conversions. Take your time and read throught the pages. NWSL has a lot of options.
I bought a digital caliper for measuring shaft diameters.
A quarterer for the driver gear replacement. Some people who are good mechanicaly do not need the Quarterer. I also bougth the Puller. I go with the least expensive tools from NWSL.
Notice, worm, worm gear, spur gear. Many modeleres confuse the gear names.
I think Nigel was trying to make the distinction, in his previous post, between “restoration”: keeping the model in original form, using only original parts; and being willing to use non-original parts, such as NWSL gearboxes, to make the engine operable again, using whatever works best of currently available components.
This is a frequent topic of discussion between people who collect brass engines to keep untouched in their original boxes (which, I know, this is not - but still, it might be considered “collectible”) and those who buy brass engines to actually operate on their layout. Nigel was just trying to understand what your personal objective is.
