Still more doodling, this time it is based on this.
I want to make sure I am doing the math correct. track at the top starts around a 42 inch radius turn (Mountain) climbs 3.5 inches for 330 degrees and crosses it self.
If I have done the math correct the total run of the turn section only is 244.88 inches, and with climbing 3.5 inches the grade should be 1.45% Does the math sound correct?
I know there would be more drag with it going around the turn. Right now I am just checking the math.
Yeah it’s actually a little lower grade, so you should be fine. ‘Only’ 263 inches of length - that’s almost 22 feet of track! I barely have that much on my main line on 3 walls of the room.
Length of run is simple - 2 x radius x 3.14. If you want to do it in your head use 6x radius, knowing the number will come out low so any grade will be less than expected.
Should be plenty to allow for the clearance - a 1.5% grade over that distance is actually 3.9" of rise. A 2% grade is more than 5" - enough to clear benchwork rather than just an HO scale bridge. The 42: radius makes for lots of length to keep the grade % down.
